Browse Forums Building A New House Re: ******* roof frame? 4Mar 09, 2008 12:45 am Building again . . with Redink Pre-start 04/12 Keys - 03/13 Finishing off. . . Painting/Floor Tiles/Carpet - 04/13 Walk In Robe/Lighting/Blinds and Moving 05/13 Gates/Front Landscaping / Pool 05/13 Re: ******* roof frame? 5Mar 09, 2008 4:14 pm Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: ******* roof frame? 13Mar 11, 2008 7:52 am Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: ******* roof frame? 18Mar 14, 2008 9:32 pm Update;
I had a building inspector out today to discuss this steel beam and brick issue and also check everything over. Unfortunately, he did not consider the stack of four bricks to be a problem He did say it was unnecessary though since they could have used the typical single brick and achieved the same overall outcome in supporring the roof. Anyway, he did pick up one major roof issue which I never would have noticed. I'm using colourbond for the roof cover and with a metal roof it's very important that the roof frame is secured to the walls to stop it lifting with the wind. They normally use metal straps, one end cemented in with the wall and the other wrapped and tightened over the rafters. In my case, while they had put straps in they appear to have made no effort in properly tensioning them so they were all but useless. The inspector said it's one of the worst efforts he's seen... He also picked up a few other items, a note for those building in WA; gaps in the brick work larger than 12mm should be packed with mortar and not simply covered over by the plasterer. He also gave me good advice on what to look out for as the rest of the tradies do their work. I think it was money well spent. I've now sent the inspectors report to my builder and we'll see what eventuates. I've told them I am holding off paying the current progress payment until this is sorted. Re: ******* roof frame? 19Mar 15, 2008 12:06 am Hmmm.
Make note to self - when buying real estate in WA - if 2007 -xx period houses - check on quality of work I'm astounded that a pile of 4 bricks is acceptable., let alone the what looks like a twisted steel beam sitting on a single brick. Steve Re: ******* roof frame? 20Mar 15, 2008 1:09 am When I raised my concern on those stacked bricks and what would happen with an earthquake the guy essentially said not to worry because all of the steel beams would likely come off anyway! Not particularly re-assuring! A few times he mentioned a particular structural engineering company that he says essentially writes the standards in WA in what I took to be a less than flattering light.
I might have to do something about this myself once I move in if it continues to bother me. A roll of duct tape each end ought to do it This is 100% true. You can not hang anything on steel frames. very frustrating 8 9161 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28529 Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 4568 |
