Browse Forums Building A New House Re: Plank embedded in slab and drainage pipe for evap coolin 2Apr 11, 2010 5:54 pm Where you are coming from is where you are going to... Re: Plank embedded in slab and drainage pipe for evap coolin 3Apr 11, 2010 6:25 pm Building SOR with Dreamstart Homes Customised Dream Dior/Summer Sensation https://forum.homeone.com.au/viewtopic.php?f=31&t=83776 Re: Plank embedded in slab and drainage pipe for evap coolin 6Apr 11, 2010 8:12 pm Where you are coming from is where you are going to... Re: Plank embedded in slab and drainage pipe for evap coolin 11May 12, 2010 9:39 am Where you are coming from is where you are going to... Re: Plank embedded in slab and drainage pipe for evap coolin 13May 13, 2010 10:27 pm Where you are coming from is where you are going to... Re: Plank embedded in slab and drainage pipe for evap coolin 15May 14, 2010 11:08 pm If you didn't find the wood on site... maybe you're right. Can't see any fragments. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Plank embedded in slab and drainage pipe for evap coolin 16May 15, 2010 12:06 am Well they made enough mess and didn't bother to clean it up. you will know soon enough if the bottom section of the board is there because the new section will pop out in no time and reveal the story. Just keep an eye on it Where you are coming from is where you are going to... The coupling, which is made from flexible PVC, needs to comply with AS/NZS 4327 which specifies the requirements for metal banded flexible couplings used in low-pressure… 1 2220 13 7040 Need more photos from around the house including your gutters. We have had 3 of the wettest years in a row for some time so that wouldn't be helping 3 7324 |
