Browse Forums Building A New House 1 May 03, 2010 7:03 pm Hi all Does anyone know what is the minimum required fall in tiled shower floors and how do we actually measure that it has been done correctly?? What are the standards for levelness of tiled floors?? Is tiled floor in general a defect if it has a 'belly' in one area (ie. is not spirit level)? Help My signature is distracting people from my wise posts ... Re: HELP! Shower Floors - What fall is required by Standard 2May 04, 2010 12:55 pm Shower are: Between 1:60 to 1:80 Other wet area: Between 1:80 to 1:100 To measure the fall get a spirit level and place it so it is level. You'll want a short level (say 300 mm). Measure the vertical gap from the floor to the level and measure the horizontal distance from the edge of the level resting on the floor and the place you measured the verticla distance. Divide the horizontal number by the verticla number to get the fall. Or, do as I do, buy a digital level. This will give you a direct readout. very handy. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: HELP! Shower Floors - What fall is required by Standard 3May 04, 2010 5:03 pm Thanks, Casa2! OK, so let's say: v = the vertical gap (measured at the deepest point) h = horizontal distance (from where I measured the vertical gap from the bottom of the fall to the edge of spirit level) x = the fall (the unknown) = ? OK, x = h / v. Let's say that h=150mm and our v = 1mm. This gives x = h/v = 150/1 = 150. So, how do I compare this number to the standard values which are expressed in a different way?! (1:60 to 1:80) and not as a single number!? My signature is distracting people from my wise posts ... Re: HELP! Shower Floors - What fall is required by Standard 4May 05, 2010 10:22 am Lex Thanks, Casa2! OK, so let's say: v = the vertical gap (measured at the deepest point) h = horizontal distance (from where I measured the vertical gap from the bottom of the fall to the edge of spirit level) x = the fall (the unknown) = ? OK, x = h / v. Let's say that h=150mm and our v = 1mm. This gives x = h/v = 150/1 = 150. So, how do I compare this number to the standard values which are expressed in a different way?! (1:60 to 1:80) and not as a single number!? ok, so what casa2 is saying is this, the ratio of 1:60 is what you want, you have measured 1mm for the vertical drop (or rise), and 150mm for the horizontal (run), this gives you a ratio of 1:150 Simple terms, the first number is is the rise (or 1mm in your case), the second is the run (150mm in your case) example: rise = 5mm, run = 300mm This would five a ratio of 5:300, which when simplifying gives 1:60 Does that make sense to you? Re: HELP! Shower Floors - What fall is required by Standard 5May 05, 2010 12:02 pm So, with my values of h=150mm and v=1mm (I will re-measure these values), the results is that my ratio is 1:150, which is waaaay outside the standards ... Even if my h=300 and v=2mm, using x= h/v= 300/2 = 150/1 = 150 (again!!!) Or, should I not actually do the division, rather replace the "/" with ":", which would leave me with 1:150 again!!!!! like here: x= h/v= 300/2 = (replace "/" with ":") = 300:2 = 150:1 My signature is distracting people from my wise posts ... Re: HELP! Shower Floors - What fall is required by Standard 6May 05, 2010 1:06 pm Lex, Yep, your fall is 1:150. This is unacceptable. Water will pond and this will be a mould, etc problem. Cheers, Casa Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: HELP! Shower Floors - What fall is required by Standard 7May 05, 2010 3:15 pm I will re-measure ... What about other areas, like hilly floors and wavy walls? What's the standard? Has anyone had those problems? My signature is distracting people from my wise posts ... Re: HELP! Shower Floors - What fall is required by Standard 8May 05, 2010 3:41 pm These are covered in the Guide to Tolerances and Standards (or similar title). It may even have the shower fall requirments, etc in it. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: HELP! Shower Floors - What fall is required by Standard 9May 05, 2010 6:25 pm I had already checked the Guide - it seems like there are no clear guidelines there. It firstly talks about "faulty" or "failing" tiling, but fails to define what that is. It mentions "uneven tiling" at the end of the chapter, but it seems to be restricted to grout. The only thing remotely resembling "wavy tiling" is "... joints that re not ... in the same plane". Can that be translated as "wavy tiling"?! My signature is distracting people from my wise posts ... Re: HELP! Shower Floors - What fall is required by Standard 10May 05, 2010 7:49 pm I think there's somethign about no more than 3 mm over 3 m of deviation in floors. Also there's definetly soemthign about walls. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: HELP! Shower Floors - What fall is required by Standard 11May 05, 2010 8:28 pm Ahaaaa, maybe I should look at the Plastering section - thanks for that! If wall tiling is uneven, the most likely cause are obviously the walls behind it ... will have a look My signature is distracting people from my wise posts ... Thank you Splashers. Tomorrow I might check if I can get a few packs of 300x300 in the same tile finish. It may be good to use these could in the shower recesses. I'm not… 4 5176 I've got a challenge here. Background is the builder has cut too deep for the slab and the slab is now below the very substantial retaining wall. It's failed occupancy… 0 18778 AS4654.2-2012 External Membranes it is "Informative" but if you get water ingress your insurance assessor will go to this straight away and if not achieved, they will deny… 9 2709 |
