Browse Forums General Discussion Re: Rainwater tanks 10Mar 08, 2008 8:39 pm Colleen Quote: All new homes and apartments in Victoria must comply with the 5 Star standard. This means it is compulsory for new houses to have: - 5 Star energy rating for the building fabric, plus - A rainwater tank for toilet flushing or a solar hot water system. - Water efficient shower heads and tap wear. Taken from http://www.5starhouse.vic.gov.au/ Yes, I quickly came to the conclusion when we were sussing out builders that they usually offer solar hot water or a water tank plumbed to the toilets, to comply with 5-star energy rating, but not both. This would depend on where you live though, I guess. We decided to stick to the solar hot water default and not get a tank with M, because a #1 flush of the toilet only uses 3 litres anyway, and I saw the solar hot water system as a much greater saving, both monetary and environmentally. We are also fortunate enough to live in an area that currently has no water restrictions, apart from the permanent ones regarding hosing of paved areas etc. I realise that the situation regarding rerstrictions could change, but we don't use a great deal of water anyway. Water for the gardens will come from a tank fed from my eventual shed which means that we will use less than we do now at our present house, which has no tank. Re: Rainwater tanks 11Mar 08, 2008 8:59 pm haywgl,
we signed up with M last yr and took both solar(free) as well as the 'flushmiser' it cost 3.5 K extra. I did enquire with flushmiser if they retrofit but the guy mentioned that plumbing to toilets was easier during the build. I am amazed how they have increased the price to nearly double!! possibly this is taking advantage of our situation. Re: Rainwater tanks 12Mar 08, 2008 9:07 pm Vpande - I am also suprised by how much the cost of things with 'M' has gone up. Reading people's past posts about 'extras' they have purchased with 'M' compared to the quotes I am getting are quite shocking. Even the base price of their houses have gone up, I think VJ mentioned when she looked at the Laguna it was around $197k, its now almost $240k
While I would liek to get the rainwater tank as well as the solar hot water, I simply can not justify the $7000k pricetag Re: Rainwater tanks 13Mar 08, 2008 10:15 pm $800 for a 3000l tak,. plus $150 for the fittings plus $100 for the slab.
DIY, no connections to grey water or mains so I can use it how I want. Of ot has a top up odd mains water, its use is still subject to water restrictions. I can hose my driveway down then wash my car and the only thing would be that it is a waste of water. Do it yourself after handover. Adrian B Re: Rainwater tanks 14Mar 09, 2008 7:27 am Adrians suggestion is great. but there has been news reports that water may be priced as petrol in future... so best to use it frugally and save where one can. check with www.flushmiser.com.au for a quote after handover. I am sure u can get the main bathroom flush and laundry going on that to save enough water. Re: Rainwater tanks 15Mar 09, 2008 7:31 am Leece .... and the tank needs to have the ability to be able to be filled with mains water if the water level in the tank gets too low. Doesn't this defeat the purpose of a tank? I would have thought a valve arrangement where when the level of the tank gets low, it switches across to mains water. Re: Rainwater tanks 16Mar 09, 2008 7:42 am When we asked M about the tank and solar hot water, we were told we could choose whichever we wanted, but they do mostly solar hot water so I'm guessing that works out cheaper for them to do.
It suited us fine too so we stuck with the solar hot water. A tank is no use unless it rains because it doesn't come full! Ray. Second Time 'Round Re: Rainwater tanks 17Mar 09, 2008 7:52 am Hi Belinda.
How big is this tank they are quoting $7K for? 10,000 litres? Does it come with a MASSIVE pump? I got a 1000 litre tank for just over $500 and installed it myself (about $30 - $40 worth of PVC pipe and a couple of hours). Add on a pump for a couple of hundred, and maybe a powerpoint for the pump, and you're done. Re: Rainwater tanks 18Mar 09, 2008 7:58 am Hey Rodda - On th paper work I has it says,
'Provide option for 2000 litre Colorbond Aquaplate round tank with auto top-up system, electric pressure pump and by-pass, connected to all sanitary flushing systems - $7,536' Hope that helps Re: Rainwater tanks 19Mar 09, 2008 8:09 am haywgl 'Provide option for 2000 litre Colorbond Aquaplate round tank with auto top-up system, electric pressure pump and by-pass, connected to all sanitary flushing systems - $7,536' That sounds very expensive to me. We're getting a 5000 litre tank, with all those same connections and accessories for $5k. Re: Rainwater tanks 20Mar 09, 2008 8:32 am Djelibeybi That sounds very expensive to me. We're getting a 5000 litre tank, with all those same connections and accessories for $5k. I agree, one of the reasons we are not opting for the system...your deal sounds much better. That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17422 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31385 |
