Browse Forums Building A New House Re: Designer kitchen upgrade - your thoughts 3Mar 04, 2008 8:08 am Grandview 36 on Beautiful Bribie Site Start Dec 5th 2007 Projected completion May 12th 2008 NOPE Handover 24th June 2008 Moved in 11th July 2008 Wating on one final thing - Still - Oct 2009 Re: Designer kitchen upgrade - your thoughts 7Mar 04, 2008 9:33 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Designer kitchen upgrade - your thoughts 10Mar 04, 2008 11:13 am Quote: Your statement about the walk in pantry only having "regular doors" is a bit confusing - does this mean that all of the other doors are going to be two pack and the pantry door is colourboard? This would look pretty ordinary unless you mean that the pantry is in a seperate section of the kitchen and not "connected" to any of the painted cabinetry. Our kitchen is like this: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ So I think just a set of internal doors would look ok. We are tossing up whether to have some overhead cupboards installed on either side of the stove After 4 years - we're in! Re: Designer kitchen upgrade - your thoughts 11Mar 04, 2008 11:28 am Your kitchen is similar to ours, Stonecutter... except our pantry doors will be in poly and the same colour as our cupboards.
I think the doors will look out of place if they aren't poly.. Re: Designer kitchen upgrade - your thoughts 12Mar 04, 2008 11:33 am Cookiemonster Your kitchen is similar to ours, Stonecutter... except our pantry doors will be in poly and the same colour as our cupboards. I think the doors will look out of place if they aren't poly. x 2. Will there be any cupboards above the fridge space? From the plans, it doesn't look like there's be sufficient depth to be a full walk in pantry as it'll be the same depth as the fridge space which would be 600-700mm. Re: Designer kitchen upgrade - your thoughts 13Mar 04, 2008 11:36 am Quote: We are tossing up whether to have some overhead cupboards installed on either side of the stove I think the more storage the better. overheads can even look good as a feature. Quote: Will there be any cupboards above the fridge space? I wouldput one here as well - storage storage [/u] Paula Re: Designer kitchen upgrade - your thoughts 14Mar 04, 2008 11:41 am Hmmm - good food for thought! I will check the fridge depth when they send me the technical drawings (rather than the not-to-scale brochure I have at the moment) After 4 years - we're in! Re: Designer kitchen upgrade - your thoughts 15Mar 04, 2008 12:13 pm If you're going Caesarstone in kitchen, you might want to upgrade to 30 or 40mm (the same thickness as laminex benchtops). I think 20mm in the kitchen makes the benchtop look too thin. I'd find out what the difference is to upgrade the package to 40mm benchtops.
However, the rest of the package is good. My kitchen glass splashback was somewhere between $1500 and $2000 without the builder's markup, so you're saving quite a bit. Cheers, Jamie Re: Designer kitchen upgrade - your thoughts 16Mar 04, 2008 12:25 pm I've been thinking about 30mm - don't like the join you see in the 40mm pieces After 4 years - we're in! Re: Designer kitchen upgrade - your thoughts 17Mar 04, 2008 2:32 pm stonecutter1309 I've been thinking about 30mm - don't like the join you see in the 40mm pieces Exactly. And what's more, they only give you edging for the bottom layer!! Demolition August 2009, Construction Started September 2009, Completed December 2010 Your build is relatively simple, I believe your job can be easily done by a good building designer, you really do not need to pay for the architect. Remember, architect's… 3 11140 Were struck with: Colorbond Ironstone Grey roof and cream windows. What color should we render and paint the garage door to tone down the cream windows? Farm House, will… 0 29001 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 40285 |
