Browse Forums General Discussion Re: Paved instead of a concrete slab??? 3Apr 16, 2010 8:46 pm Why don't you get some quotes to fix it & use it as leverage off the purchase price? I would look at worse case senario. Quote: I would really need to love the house to take that risk AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6973 That's brilliant would appreciate if you have you can locate the other doc so I can use it with my discussion with the building surveyor 10 2524 yep, clearly mark where the infloor heating pipes are before drilling or nailing 1 6476 |
