Browse Forums Flooring & Floor Covering Re: Should carpet be laid before or after WIR inserts instal 2Mar 27, 2010 9:45 am It depends on the design of the fittings, but usually its best to do the fit out, and then have carpets fitted. It will still be nice and neat, and will better in the long run. If ever you have water damage there, its a PITA if carpet is laid beneath inbuilt fittings. Ash. Re: Should carpet be laid before or after WIR inserts instal 4Mar 27, 2010 10:40 am ^ I think Ash recommend the other way around?? Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! I had new concrete laid, extended the alfresco and had the sidewalks concreted too. I noticed the concreter didn't put the expansion foam anywhere, there are expansion… 0 8184 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15907 I am in the same situation, would you be able to give some insights in to this? I am in SA 8 17288 |
