Browse Forums Kitchen Corner Re: glass splashbacks 2Jul 07, 2005 12:10 pm Iām not sure how to prep the surface but I would recommend you use opti-white low ionised glass. Because normal toughened glass has a green tinge which can ruin the colour applied on the back. Re: glass splashbacks 4Jun 22, 2006 5:23 pm 3mm is way too thin. 6 - 10mm toughened is best. Normal glass has a high iron content and will give a green tinge to whatever is applied to the back of it (white especially).
Starfire glass has less iron content and will not affect your chosen splashback colour. Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you 0 39047 What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only… 1 12391 |
