Browse Forums Building A New House Re: Preliminary Plan....Question 3Feb 18, 2008 9:08 pm Kryten Hi Fiona Not 100% if this applies to your Council but I found this under the Wyndham Council webpage: "Fences on side or rear boundaries The total length of fences that are more than 2 metres in height and that are constructed on, or within 150 millimetres of, a side or rear boundary of an allotment must not exceed, along the boundary, the greater of the following lengths: 10 metres plus 25% of the remaining length of the boundary of the allotment; or the length of any wall or carport constructed on an adjoining allotment that is on or within 150mm of the boundary of that allotment and that abuts those fences. A fence constructed within 150 millimetres of a side or rear boundary of an allotment must not exceed: an average height of 3 metres; a height of 3.6 metres along the boundary If a fence abuts an existing wall it may be constructed to the same height as that wall. This requirement does not apply to a fence if: it is constructed on or within 150mm of a boundary that is a side or rear street alignement it is not more than 2.5 metres in height; and it is provided to comply with overlooking requirements; and the part of the fence between 2 metres and 2.5 metres in height has between 20% and 25% of its area open." Maybe someone has come across this before and can give you a definitive answer. Dana BLoody hell, Dana! Talk about a lot of stats about nix! Fiona Re: Preliminary Plan....Question 4Feb 18, 2008 9:11 pm Yeah, it's not the most helpful but when I typed in fence and 25% that's what came up - I wasn't sure if your block comes under Wyndham or not. As I said before, I hope that someone else has come across this and can give you the plain English version
Dana Dana -------------------------- Building with DFH - carpet installed! Re: Preliminary Plan....Question 5Feb 18, 2008 9:13 pm Thanks, Dana.....and, for the record, I'm pretty sure we *will* be coming under Wyndham. If that little quote is anything to go by, we're in trouble when it comes to dealing with bloody councils! LOL
Fiona In NSW the maximum deposit for building work is 5% until the builder provides HBCF insurance 1 4918 i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17460 5 10583 |
