Browse Forums General Discussion Re: Glass sliding wardrobe doors 26Mar 05, 2010 10:52 pm I like the white - breaks it up a bit - makes it look a bit more casual/less sophisticated (IMO) not sure if that was the look you were going for? Sleven Moved into our Atlantique MkII 36 by Carlisle Homes Re: Glass sliding wardrobe doors 27Mar 06, 2010 7:12 am I like the all black ones think they are gorgeous. I am actually thinking of having them to use as sliding doors to block off my home theatre and also in the bedrooms that have built in wardrobes. Have a look on the packers website, not sure if you have packers where ever you are but here in SA they do black doors and have a huge range of designs. V Pls help! The black marks show where our outdoor entertaining area would be along side of house as we have an irregular backyard and want to make use of the side as… 0 4593 Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3481 ![]() Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 5642 |
