Browse Forums Bathrooms and Laundry Re: Leak from behind tiled kickboards under bathroom vanity 2Dec 22, 2009 9:21 pm Where you are coming from is where you are going to... Re: Leak from behind tiled kickboards under bathroom vanity 3Dec 23, 2009 6:29 am Possumchops Now the proud owner of 3.7acres of Serenity. Colour selection completed! Soon to go to council. Re: Leak from behind tiled kickboards under bathroom vanity 5Dec 23, 2009 12:46 pm How the hell did I become a senior member!? I know nothing! Re: Leak from behind tiled kickboards under bathroom vanity 7Jan 03, 2010 9:08 pm How the hell did I become a senior member!? I know nothing! Re: Leak from behind tiled kickboards under bathroom vanity 9Jan 09, 2010 8:53 pm How the hell did I become a senior member!? I know nothing! Re: Leak from behind tiled kickboards under bathroom vanity 10Jan 23, 2010 5:54 pm How the hell did I become a senior member!? I know nothing! Re: Leak from behind tiled kickboards under bathroom vanity 12Jan 28, 2010 5:10 pm How the hell did I become a senior member!? I know nothing! Re: Leak from behind tiled kickboards under bathroom vanity 13Feb 26, 2010 1:06 pm How the hell did I become a senior member!? I know nothing! Re: Leak from behind tiled kickboards under bathroom vanity 15Feb 26, 2010 8:59 pm That sounds about right...it sounds not too bad. We can't relocate to outside as we're in an apartment so it's got to be inside, and the only place it can fit is where it currently is...and in terms of appearance, it HAS to be in a cupboard set up or we'd be looking at a hot water system tank all the time in our bathroom. Ugh! Also, our cats would be getting in and trying to find their way behind it, which won't do. Do all plumbers have access to this Aqua Max brand? I've heard they only have 2 brands usually - Rheem and Dex. How the hell did I become a senior member!? I know nothing! Re: Leak from behind tiled kickboards under bathroom vanity 16Mar 05, 2010 8:43 am yes, aquamax is a common brand. its actually owned by rheem, but is quite a bit cheaper. the one brand to stay away from is dux. i replace a lot of hot water units and many of the dux units i replace have begun leaking not long after the warranty period has expired. Re: Leak from behind tiled kickboards under bathroom vanity 17Mar 05, 2010 8:33 pm Aaah, cool. I will definitely avoid Dux then! Thank you! How the hell did I become a senior member!? I know nothing! Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while… 0 5111 Transform your bathroom into a sanctuary of calm and sophistication with Hera Bathware's Bathroom Vanity Collection. A standout… 0 12825 If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while. 2 20309 |
