Browse Forums Flooring & Floor Covering 1 May 06, 2007 7:21 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: 9 Tips for Buying and Owning Carpet 4May 09, 2007 7:48 am Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: 9 Tips for Buying and Owning Carpet 6Feb 21, 2010 12:06 am Vundaful! If you do spend up big on underlay then if you want to replace your carpet and the underlay is of sound quality, can you get away with using it again for the new carpet? Some people do it, but the answer is NO. A new carpet should be layed on new underlay. Australian Standard 2455.1:2007 states that underlay should have the same or greater life expectancy as the carpet (or sumthin like that... couldn't be bothered lookin it up). If say the carpet was changed for some reason within the first year or two maybe it'd be ok, but its best to lay new carpet on new underlay. Ash. Re: 9 Tips for Buying and Owning Carpet 7Feb 21, 2010 11:21 am Mills can, and do, make carpet down as low as 3.60 after the salvage is cut off. Work on 3.60 and you won't be dissappointed. On the ACCS ratings - It is an industry funded rating scheme - so personally I don't get too excited about the ratings. If it was 100% independent, then I would, but I have seen too many ratings that are just ridiculous. I have seen carpets with commercial ratings that are not even good enough to go in a house - you just shrug your head and ask how...... Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7231 Thank you so much. This has been very helpful. We definitely wish to settle and get these people out of our life. They are trying to charge us interest on late… 7 14280 Yeah I don't know why I came to a forum. Place is full of wierdos/pedos thought internet may help but I suppose I'll try my luck with someone in person. Cheers. I tried… 0 6447 |
