Browse Forums General Discussion Re: How to make a bed taller? 2Feb 13, 2010 10:02 pm Where you are coming from is where you are going to... Re: How to make a bed taller? 10Feb 15, 2010 12:21 pm There are lots of ways to make a bed taller. If it's an ensemble, you can simply use longer legs. We have a collection of legs from ensembles we've had previously and they vary in height. Our current ensemble is VERY thick - so it's a highish bed even with very short legs. If it's a mattress sitting on slats on a bed base, then usually it's a relatively straightforward job to drill extra screw or bolt holes to allow the brackets holding the base to be raised by the required amount. If all else fails, buying a thicker mattress may be the go.... Cheers zeke Re: How to make a bed taller? 11Feb 15, 2010 1:04 pm I wanted height for under bed storage and looking around couldn't find what I wanted, so I made a new frame from scratch, as having a double bed in a 3.5x4.0m room isn't condusive to lots of available storage. We raised it so it has about 45cm under the frame. its a fairly simple steel construction, took a couple of weekends including the design, cutting welding and painting. Cost all up was around $200 in materials. So yeah just one option to consider. Our Build - Places Fairhaven 23+ - https://forum.homeone.com.au/viewtopic.php?f=31&t=28045 Our Landscaping - Belial's Backyard - https://forum.homeone.com.au/viewtopic.php?f=19&t=45375 Re: How to make a bed taller? 12Feb 15, 2010 2:04 pm onc_artisan :th: Leg sleeves Yeah, you can get these from Bunnings, to make beds, tables etc. taller. Incidental, we made our old dinning room table shorter, and used it as a coffee table for the theatre room. Not sure who you're building with, but I moved in recently to a 11month scheduled, 8 month actual build on the South coast/Illawarra NSW 3 6015 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10452 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61674 |
