Browse Forums Building Standards; Getting It Right! Re: Colorbond roof laid with overlap facing into the weather 6Feb 03, 2010 7:37 am theyetti I came across the following document that might help your cause, unfortunately it's dated 2007 but the standard is probably still current. Look under laying procedure for the relevant information. http://www.colorbond.com/files/dmfile/T ... er2007.pdf Thanks yetti, I appreciate that more than you think! I have had a bit of bad luck in my house build (see 'Issys Hamilton Alfresco' in building a new house). I wanted to find out if the roof thing was against the building code or if it was just a "recommendation" before I added it to my thread. Cheers again, Issy PS- Thanks Arcadia for your input aswell Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10251 You should pressure clean your roof first and make sure the paint you buy also is anti mould. 4 18744 I had new concrete laid, extended the alfresco and had the sidewalks concreted too. I noticed the concreter didn't put the expansion foam anywhere, there are expansion… 0 8147 |
