Browse Forums General Discussion Re: Slope in block 8Jan 22, 2008 11:00 am steveadl01 Someone mentioned to me that I may run into problems with drainage as the block is sloping away from the street. Then it'll be waterfront property. Bonus! Or is that waterback property? Re: Slope in block 9Jan 22, 2008 11:41 am You also need to be aware of the tax implications of becoming a developer and make sure you step on the right side of the line for that one once you get started.
Re Drainage - yes it needs to be catered fro and if you have lots of concrete, it is going to change what is already installed pipe sizing wise etc. Make sure you review all costs before you start diging. Steve A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 226482 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 25765 Hi All, We have recently purchased a sloping block (3.5m fall building envelope, 6m overall). Just wondering if you know of any good builders that you would recommend for… 0 2811 |
