Browse Forums General Discussion Re: concrete path around the house............ 2Jan 08, 2010 1:42 pm Where you are coming from is where you are going to... Re: concrete path around the house............ 4Jan 08, 2010 10:09 pm In grey? $1400ish for concrete, probably the same for labour + GST Where you are coming from is where you are going to... Re: concrete path around the house............ 5Jan 08, 2010 10:19 pm onc_artisan In grey? $1400ish for concrete, probably the same for labour + GST wow, that's pretty good. I was working off $50sqm as didn't realise that narrower areas cost more. Cheers Re: concrete path around the house............ 6Jan 08, 2010 10:33 pm That was a pretty loosish price for straight stuff. But pretty honest price. Don't expect it from every grano Where you are coming from is where you are going to... Re: concrete path around the house............ 7Jan 08, 2010 10:54 pm Geeez, that seems good! Phew! And a good tip about the narrow path! I wonder what is the reason for the narrower being pricier More tedious? Not easy to sway some wide tools within the formwork? Just because they can ?? My signature is distracting people from my wise posts ... Re: concrete path around the house............ 8Jan 08, 2010 11:07 pm Lex, concrete goes further so more forms, more distance to walk, push a barrow, finished edges, control jointing, cutting mesh, plastic. It is a LOT easier to pour a heap in a big square box and smooth it off. Where you are coming from is where you are going to... Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12950 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8566 Thank you so much for your response. I have drawn a pedestrian gate in - for curb appeal, let's see how much costs come in at. I think you're right - if we decide to… 2 6574 |
