Browse Forums Flooring & Floor Covering Re: How do I remove blood from carpet? 2Jan 04, 2010 4:48 pm Building with Homebuyers Centre El Questro! My building thread..viewtopic.php?f=31&t=19421 Brickies started 5/10 Re: How do I remove blood from carpet? 5Jan 04, 2010 7:31 pm mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: How do I remove blood from carpet? 6Jan 04, 2010 7:35 pm Building with Homebuyers Centre El Questro! My building thread..viewtopic.php?f=31&t=19421 Brickies started 5/10 Re: How do I remove blood from carpet? 7Jan 05, 2010 12:28 am Hi Judie, How did the blood contact the carpet? Normally, blood will not penetrate far into the wool carpet, as the surface tension and other characteristics of the wool fibres keep it very much on the surface. So if fresh, it can often be removed quite easily with a damp cotton flanel, nappy or towel. Avoid overwetting though. Some Woolsafe Approved spot cleaner would be good to use, but DON'T apply it to the blood. Apply a little to the cotton nappy, and blot. This way the blood is drawn up and absorbed into the nappy. Work carefully. If you are not sure where remaining spots are, you can spray a light mist of hydrogen peroxide (no stronger than 3%) over the area, and you will see a reaction if it contacts blood. Then you can spot clean the blood. NO rubbing or scrubbing of the carpet. Just gentle blotting without overwetting. Call me if you have a prob. If there is a larger area of blood pooled, it is best to get in a professional. Ash. How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11837 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7076 |
