Browse Forums Landscape & Garden Design Re: DIY retaining wall advice 4Jan 04, 2010 6:42 pm Hey mate, thanks for the detailed reply. Do you have a photo of the concrete sleepers, the reason we didn't want to use the redgum sleepers is that the whole house is rendered and we want a smart clean look, concrete sleepers may be a good in between. If you don't have a photo can you give me an idea where you will get them through. Cheers Hunts Re: DIY retaining wall advice 5Jan 04, 2010 11:49 pm Sleepers were ordered today, so will be 7 days till delivery. Plain concrete sleepers are fairly common around here so no problems of getting a photo of a wall, even if its not of my own ![]() I'm not a fan of the concrete sleeper look either and I was dead against it when we first decided to build a wall, but it is going down the side of the house that will be rarely seen by anyone else other than me and the other half and I plan on painting it when finished to colour it up a bit. Even thought about using slate crazy paving once the wall has settled to clad it so it looked like a rock wall but at $10 for a 400x400 tile it was going to costly as well. The other reason for not using timber is that there are white ants in the area, and I only want to build the wall once, so nothing that would rot or be susceptible to white ant damage. Will get a couple of pics tomorrow if I remember. Cheers. Re: DIY retaining wall advice 6Jan 07, 2010 8:21 pm Check out Boral's website, they have some DIY guides for their block retaining wall systems. just a 200mm footing of crusher dust or sand is required, level and compact then string line the first course and take your time... lay down some agg pip and drainage gravel and start laying the blocks on top of each other. Piece of cake. I tink you have chosen the best DIY method all the best! Re: DIY retaining wall advice 7Jan 08, 2010 10:43 pm hey dirty darren... where are you ocated?? I was calling up suppliers in melbourne for prices on the concrete sleepers and they were all around $40 each?? I think 20sounds far better!!! Re: DIY retaining wall advice 8Jan 08, 2010 11:21 pm Hey DD so about $70 L/M. About 0.09 cu mtrs per L/M Concrete cost of $20 L/M... Hmmm Where you are coming from is where you are going to... Re: DIY retaining wall advice 9Jan 09, 2010 7:22 am ![]() hey dirty darren... where are you ocated?? I was calling up suppliers in melbourne for prices on the concrete sleepers and they were all around $40 each?? I think 20sounds far better!!! Located in Wodonga, ordered them through a local paver company that makes and supplies them, MCG Pavers. Ended up being $24 each for a 1800L x 200H x 65 concrete plain finish sleeper (the $20 ones were or special at a different place, went back to order and told me they were $26 each ![]() Everyone else that has them sells them for $26 each for same size, made by Trojan Stone. Colour ones are $30-$36 from memory and any textured finished ones (rough brick look or natural timber look) were anywhere from $40-$50 each Here in Wodonga we are limited to the amount of landscape suppliers, only a few of them sell plain concrete sleepers (but nearly all sell textures finish ones and / or timber) , plain concrete is much harder to come by than I thought. Cheers. Re: DIY retaining wall advice 10Jan 12, 2010 8:07 pm Hey DD... i spoke to Wayne today about the sleepers, he is just wonderful. I faxed him a rough copy of what i want to do, he marked it all out and drew it to scale and sent it back to me with a quote... What a dream ![]() I never thought it would be that easy... 2 week turn around cause i need 175 sleepers, but i guess well worth the wait... not to choose a colour... Just a question... did you use steel or gal posts??? Re: DIY retaining wall advice 11Jan 12, 2010 8:23 pm ![]() Sleepers were ordered today, so will be 7 days till delivery. Plain concrete sleepers are fairly common around here so no problems of getting a photo of a wall, even if its not of my own ![]() I'm not a fan of the concrete sleeper look either and I was dead against it when we first decided to build a wall, but it is going down the side of the house that will be rarely seen by anyone else other than me and the other half and I plan on painting it when finished to colour it up a bit. Even thought about using slate crazy paving once the wall has settled to clad it so it looked like a rock wall but at $10 for a 400x400 tile it was going to costly as well. The other reason for not using timber is that there are white ants in the area, and I only want to build the wall once, so nothing that would rot or be susceptible to white ant damage. Will get a couple of pics tomorrow if I remember. Cheers. Hey DD, can we see pics now??? please ![]() Re: DIY retaining wall advice 12Jan 13, 2010 6:35 pm Scrappin - I used black steel posts (ungalvanised). It was heaps cheaper than the galvanised stuff. I painted the posts with a priming oil (Penetrol) before painting with a coat of Septone chassis black paint. The posts will have another coat of paint after the sleepers are in. Here are some pics of walls in our area, and funnily enough, the first pic is almost the exact same profile as the one I am building, didn't realise that until I took the photo, and this was the wall that put me off concrete sleepers to start with ![]() Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 2nd is of coloured concrete sleepers Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ and another plain concrete wall Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And now some of mine - Black steel posts, before and after rust treating (sorry pic is sideways ) I have welded in a 3mm steel plate at the right height for the sleepers to sit on, you can see it halfway down the black post. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Stuff used for rust treating - Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Construction has started, 4 posts are in ![]() Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: DIY retaining wall advice 13Jan 13, 2010 6:47 pm DD, looking good. Did you use rapid set concrete to hold them in?? I got my quote back yesterday, now just have to start saving...LOL Re: DIY retaining wall advice 14Jan 13, 2010 8:14 pm ![]() DD, looking good. Did you use rapid set concrete to hold them in?? NOT rapid set concrete (I heard it wasn't suitable for structual applications such as retaining walls, don't know how true it is), but went and bought aggregate, sand and cement to mix my own. I'm lucky enough to know a few people with a cement mixer so I could borrow one at no cost and its easy to do. Re: DIY retaining wall advice 15Jan 13, 2010 8:19 pm I didnt think you could. I got a quote on a truck bringing some, it was about $700! I almost fainted!!! Re: DIY retaining wall advice 18Jan 14, 2010 8:29 pm ![]() just another thing those plain concrete sleepers, can you render them??? Not sure if you can, I've heard walls move a little bit due to settling and maybe expand/contract with the heat the same as any other concrete would. I'd think if I was going to do something like rendering I would "bag" it instead. A bit cheaper and the finish isn't as straight and neat as rendering so any small cracks that appear wouldn't be as obvious. I may even spray my sleepers with a paving paint yet to colour it up. Will see what it would cost and what colours I can get. If you really wanted to reder the wall, you may want to think about ordering concrete slabs to fit between the posts rather than individual sleepers. I saw this yesterday when wandering around the neighbourhood, never seen slabs used before in place of sleepers but I imagine it would be more costly. Will keep posting pics as I progress, but will be slow as I'm only concreting in 1 per day after work ( and its 40+ degrees, way too hot to do anymore than concrete 1 post in and dig out the hole for the next one ) Hoping this weekend I can at least 6 more or so in. Cheers. Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 22767 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 48491 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 7099 |
