Browse Forums Building A New House 1 Jan 14, 2008 5:25 pm We are goign the final inspection alone, not having an independant inspector with us for the final stage, money things really, though we have up until this point.
I have a list of this to look closely at but was just looking to see if i have missed anything on my list of things, Anyone want to put up their suggestions of things to check. Thanks Building again . . with Redink Pre-start 04/12 Keys - 03/13 Finishing off. . . Painting/Floor Tiles/Carpet - 04/13 Walk In Robe/Lighting/Blinds and Moving 05/13 Gates/Front Landscaping / Pool 05/13 Re: Inspection tomorrow 2Jan 14, 2008 5:33 pm I can’t believe you’re doing final inspection!!!
WOW…your home seemed to be build so fast……….. Or have I got the wrong person???? Lost my car today in the car park……so now that tells me I’m in trouble! Good luck with your inspection, I’m afraid I’d be here all night giving you pointers, but I think you may have learnt enough to help you threw the process by now. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Inspection tomorrow 3Jan 14, 2008 5:42 pm No the house has been built really quickly, especially for WA Building again . . with Redink Pre-start 04/12 Keys - 03/13 Finishing off. . . Painting/Floor Tiles/Carpet - 04/13 Walk In Robe/Lighting/Blinds and Moving 05/13 Gates/Front Landscaping / Pool 05/13 Re: Inspection tomorrow 4Jan 14, 2008 8:06 pm wow.. that's exciting and scary?
unfortunately, i can't say anything about final inspection as i haven't experienced it and we're still at slab stage at the moment. would love to hear other people's pointers... good luck and look forward to your updates afterwards. ----------------------------------------------------------------------------------------- Built the Nevada 42 Next project - landscaping! Re: Inspection tomorrow 5Jan 14, 2008 9:30 pm Some information i culled from the internet, hope it helpful. I think if i were you i will take a few friends. If your supervisor might want to guide you, go with his flow first. However, you need to go over again alone at slower pace and with friends.
Also, goodluck for tomorrow. here are the info: Inspection pre-handover http://www.newhomeinspections.com.au/4.html http://www.handovers.com/index.php?opti ... e&Itemid=5 PRE-HANDOVER INSPECTIONS Most supervisors will rush you through the Handover process, preying on your eagerness to move into your new home and your ignorance of what's acceptable or not. You should remember that a supervisor goes through this process 1 or 2 times a week, while most home owners would only do it 1 or 2 times in their life, so who do you think is the more skilful at it? That's why this inspection is a must for all New Home Owners. Our inspection covers more than 500 aspects of your new home, including but not limited to: Externally * The brickwork for level, plumbness, straightness and to make sure that it is in line. * The proper placement of Articulation Joints, Flashings and Weepholes. * The correct clearances between the windows and their brick sills. * The correct bearing of the brick walls onto the concrete slab. * A simple strength test is carried out on the mortar. Further testing may be recommended. * Chipped bricks and/or holes imperfections in the mortar finish. * The guttering, fascia and eaves for their level, straightness and correct installation. * The roofline and tile installation. * All glazing for scratches and chips. * All infills, cover boards and linings are checked for correct installation. Internally * All doors for correct clearances and function, as well as the door furniture for its operation. * All windows reveals are check for bows, sagging or twists that may indicate improper fitting. * All plaster joints for tool marks, scratches and sanding ridges. * All ceilings for correct installation and for visible joints. * All cornice lines for level and straightness. * All walls and the skirting boards for their straightness. * All external corners for their straightness and to ensure that they are in line. * All kitchen cupboards and vanities and the bench tops for scratches and correct installation. * All tiling & grouting for level, straightness and finish. * All cut-outs around taps for correct sizing. * All tile junctions and joints that should be caulk sealed. * All painted surfaces for coverage, blemishes and paint runs. As well as the surrounding areas for over painting and paint where it shouldn't be. Nail holes are also checked for proper filling. * All showerbases are checked for correct installation, inline with the manufacture's guidelines. * All baths are checked for proper support. * All other plumbing fixture and fittings for correct installation. * Plus many other items. Inspection includes: * Inspector on site for a maximum of 3 hrs (up to 180sq mtrs), 4 hrs (up to 300sq mtrs), 5 hrs (up to 420sq mtrs), others by agreement. * A comprehensive and detailed written report within 3 business days. * Any further information and/or telephone support required after our reports are delivered. Re: Inspection tomorrow 6Jan 15, 2008 9:29 pm I would still recommend to get a private inspector, their professional knowledge would definitely save you lots of trouble.
Let's say you found a problem somewhere, I bet the builder would come up with hundred of reasons using various jargons and terms which you don't understand and wouldn't have a clue about how to argue..... i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98776 you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5420 Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6627 |
