Browse Forums General Discussion Re: Staples in my lovely tas oak floor :/ 2Nov 22, 2009 10:56 pm Where you are coming from is where you are going to... Re: Staples in my lovely tas oak floor :/ 6Nov 23, 2009 10:29 am Building on the Sunshine Coast - Land settled 22nd July 2009 Building contract finally signed (after much deliberation on our part) 11th November 2009 Building commences 25th January 2010 - small local builder End of June - almost completed fit out 26th July - MOVE IN DAY!!!!!!!!!!!!!! Re: Staples in my lovely tas oak floor :/ 11Nov 23, 2009 2:13 pm Where you are coming from is where you are going to... Re: Staples in my lovely tas oak floor :/ 18Dec 17, 2009 9:17 pm I finally finished Took me probably 4-5 days all up and my knees and back are fu.... very sore! However I'm so pleased to be done! My technique improved over time but even then I still got say 25% snaps in some bad patches. Eventually I just used my smallest nail punch (which has a rubber sheath) and drove it through until the staple was almost out. At this point almost always the top has broken and one end is loose and the other end is firmer. I then used the extractor tool from Bunnings that's been my savior and got fairly good results. Any I couldn't get out (after cursing them for a few seconds) I ground down with the angle grinder then hole punched in. CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16567 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17528 i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17286 |
