Browse Forums Building A New House 1 Dec 08, 2009 2:15 pm Building at Kellyville Ridge - First Home buyer 11/5/10 - Port-a-loo delivered hahahaha 14/5/10 - Land was scraped (NEED TO GET RID OF ALL THIS UNWANTED DIRT) 20/5/10 - Concrete Piers all 45 of them. 21/5/10 - Plumbing 27/5/10 - concrete slab completed Re: Hot Water system Solar or Gas? 4Dec 08, 2009 2:47 pm Building at Kellyville Ridge - First Home buyer 11/5/10 - Port-a-loo delivered hahahaha 14/5/10 - Land was scraped (NEED TO GET RID OF ALL THIS UNWANTED DIRT) 20/5/10 - Concrete Piers all 45 of them. 21/5/10 - Plumbing 27/5/10 - concrete slab completed Re: Hot Water system Solar or Gas? 8Dec 08, 2009 9:21 pm IF you can afford gas boosted solar then go for that. We have electric boosted solar atm and it's great, our electricity bill in summer is lower (run reverse cycle air con in summer and heating in winter) so the only variable between seasons is the hot water essentially. We've previously had instantaneous gas and that was brilliant too. I'd love gas boosted solar though and we have included it as an option but may ditch it if we can't afford it in our build knowing that gas is a better option than electric anyway. Gas is cheaper than off peak electric. Solar is cheaper than both of those but it takes longer to recover the cost of set up too. Re: Hot Water system Solar or Gas? 9Dec 08, 2009 10:35 pm We have natural gas to the house so we went for a solar with a gas booster, cost $2000 more than the gas system but with energy prices going up and we plan to be in this house of at least 10year it was worth the extra cost. Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20376 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14374 For our new build in NSW we opted for a heat pump with a 315L storage tank. Early days yet as we only moved in 6 weeks ago. Haven't run out out of hot water though. Ours… 7 3736 |
