Browse Forums Building A New House Re: Where to place downlights 9Nov 16, 2009 4:25 pm http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Re: Where to place downlights 10Nov 16, 2009 11:12 pm Hi Cyberman, i guess the beauty of designing down lights for your own home is that you would probably have an idea where cabinets and other large furniture will be going. when placing DL's 0.5m from the wall you have a great opportunity to place some art on the the wall and the DL will do a great job, 1m away unless you adjust the light will miss the wall decor. good work with installing interesting center fittings, even with out knowing what was installed i'm sure you would have achieved a much better mood and effect from this ! Re: Where to place downlights 11Nov 17, 2009 8:00 am Lighting Designer when placing DL's 0.5m from the wall you have a great opportunity to place some art on the the wall and the DL will do a great job, 1m away unless you adjust the light will miss the wall decor. Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 15891 Appreciate that Chippy. I won’t do sand under pavers and will connect all up under pavers, however I was going to do: 1) Roadbase compacted with manual hand tamper 2)… 10 18634 |
