Browse Forums Bathrooms and Laundry Re: Shower tiled or ? 4Nov 13, 2009 6:19 am Possumchops Now the proud owner of 3.7acres of Serenity. Colour selection completed! Soon to go to council. Re: Shower tiled or ? 6Nov 13, 2009 1:43 pm Andrew Crawshaw Director Smarter Bathrooms Full Design, Build and Project Management www.smarterbathrooms.com.au Re: Shower tiled or ? 7Nov 13, 2009 1:53 pm squidgy and a wipe with towel after use. Will last forever without mould. My parents bathroom still looks new after 20 years on the first silicone application and the original grout. Is a bit of a b%&^ch to get into the habbit of but once you get everyone over that initial hurdle.... Jack Re: Shower tiled or ? 11Dec 26, 2009 5:47 pm Hi there, I know it's been a while since this post was commented on, but we were recently in this same position and can relate. I hate cleaning the shower!!! It takes forever to clean the grout and is such a pain so when we renovated our bathroom we looked at other alternatives and decided to go with ceramalite panels which are I guess like a laminate panel and they have been nothing but trouble!! Now I wish that I had stuck with tiles and would def go back to cleaning tiles if given the option! I also think a dark tile in the bathroom looks great and I would advise to go with tiles because as much as they are a pain to clean, you don't want the alternative! Hope this helps a little if you are still unsure or deciding what to do! Bek Bek I'm back Re: Shower tiled or ? 13May 18, 2010 10:26 pm Acrylic wall sheets work great! But glass would look the best, but works out the be some $200 per sqr metre. I think it has to be at least 12mm toughen glass and then have to get some one to install it. I personally think tiles look the best, but grout is porous and will has the problem of mould growing in it. Marbletrend has acrylic walls, however, I wouldn't get the one with the moulded soap holder, looks like trouble. Make sure you get acrylic walls that are PVC capped acrylic, I used some cheap walls from a major green home ware centre, it wasn't suitable for wet areas. Re: Shower tiled or ? 14May 26, 2010 2:01 pm I've found these guys do poly marble bases, there is a small write up on poly marble. http://www.showerline.com.au. Also I read this that might help also - http://www.improvemyhome.com.au/articles/bathrooms/bathroom-shower-bases No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4937 Thank you so much. We ended going with the terrain that’s part of our brick. 2 2540 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9568 |
