Browse Forums DIY, Home Maintenance & Repair Re: Brick Repointing 2Dec 20, 2006 12:31 pm I had mine done professionally, and it was worth every cent. They make it look easy, but trust me, it's not.
Removing paintwork isn't hard though. If you have an electric drill, get a couple of rotary wire brushes from bunnings...three or four dollars, put one in the drill and just scrub the paint off. Make sure you wear protective glasses and gloves etc though. Those little bits of wire break off. If all you can see are obstacles, you have lost sight of the goals Re: Brick Repointing 4Dec 22, 2006 6:55 pm morganj Thanks for that. Did you get a builder in to do the repointing? A plumber mate of mine knew a brickie who came out, repointed where it was needed and replaced a few bricks, and filled up a few holes. Had the whole thing done in a day. It would have taken me a week to do a job half as good. If all you can see are obstacles, you have lost sight of the goals Re: Brick Repointing 5Dec 22, 2006 7:46 pm If your getting a brickie in, its good time to put in some extra vents if needed too. 2 8406 I should have followed up on this thread. So, the pier foundation wasn't large enough on the side it was leaning towards, and the NBN cable went through the pier, just… 8 12181 Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7317 |
