I've got a small levelled area about 9-10sqm that I want concreted to a depth of 100mm.
Any recommendations on the best way of getting it done? Open to any option that doesn't involve the use of a cement mixer myself.
Browse Forums Paving & Concreting 1 Oct 30, 2009 9:31 am I've got a small levelled area about 9-10sqm that I want concreted to a depth of 100mm. Any recommendations on the best way of getting it done? Open to any option that doesn't involve the use of a cement mixer myself. Building Masterton Overture Re: Best option for 9sqm of concrete 2Oct 30, 2009 9:45 am Where are you Banj? Where you are coming from is where you are going to... Re: Best option for 9sqm of concrete 4Oct 30, 2009 1:59 pm Bugger I have no one there ATM. It is only about a cubic metre You will have a devil of a time getting someone there without big bucks Where you are coming from is where you are going to... Re: Best option for 9sqm of concrete 6Oct 30, 2009 4:38 pm Yep... It would be about 3 mixer loads (3.3cu foot barrel) or 10 barrow loads... Not the way to go to get a flat good floor, with out lots of ex' Where you are coming from is where you are going to... Re: Best option for 9sqm of concrete 7Nov 22, 2009 3:58 pm Do you concrete taxi in Canberra, they mix small quantities of concrete on site. I have attached a link. Cheers Lou http://www.concretetaxi.com http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Hi, I'd like some advice on the best option please on the estimate options we've been provided from our builder. This is for the… 0 4066 Newbie question for flooring options. We are thinking of changing the flooring for bedrooms and passage area. Last time we looked at flooring options was almost 8years… 0 3519 Would also like an opinion from anyone that has used xcem over hebel for floors. Thanks 1 14228 |
