Hi,
We quite like the textured carpet in the cavalier bremworth cobblestone range, has anyone got this carpet or looked at it? Thanks
Browse Forums Flooring & Floor Covering Re: cavalier bremworth cobblestone range 4Oct 27, 2009 3:04 pm Looks like a very durable, hard wearing carpet. Being loop pile, it will feel a bit firmer and look a little more 'formal' than other carpets. Should have very good appearance retention too. Only reason is may be cheaper than the cut pile carpets is it costs a lot less to produce a loop pile than a cut pile carpet. Being loop pile, its very unlikely to have pile reversal shading issues. It will require a good installer to make joins neatly. So its matter of your choice if you like the carpet. Not sure about underlay types in NZ. Thought they would be the same. Contact Bridgestone direct, as may retailers will feed you cow manure. Ash. Re: cavalier bremworth cobblestone range 5Oct 27, 2009 4:18 pm royalblue Looks like a very durable, hard wearing carpet. Being loop pile, it will feel a bit firmer and look a little more 'formal' than other carpets. Should have very good appearance retention too. Only reason is may be cheaper than the cut pile carpets is it costs a lot less to produce a loop pile than a cut pile carpet. Being loop pile, its very unlikely to have pile reversal shading issues. It will require a good installer to make joins neatly. So its matter of your choice if you like the carpet. Not sure about underlay types in NZ. Thought they would be the same. Contact Bridgestone direct, as may retailers will feed you cow manure. Ash. Many thanks Ash, will contact bridgestone about Prime. I've kept a little notepad file with the tips you have given to ensure carpet is layed well which I intend on making a condition of any sale . So far it seems the norm that power stretchers are always used so thats one 1 good thing at least. Cheers. MATE!!! I've checked their website and it's a 90% match at least. I've just called them and sent the pic through to confirm it's the same product. Thank you heaps. 3 6515 Probably efflorescence Salts coming out of sand, cement products and mortar Water brings them to surface and when evaporates it stays Extremely difficult to get rid of 1 11576 |
