Browse Forums Building A New House Re: Site costs!!! anyone building/built in Rose Grange Tarneit?? 2Oct 26, 2009 2:28 pm From what I understand many areas out west are requiring H or even P class slabs. Even a fixed price site cost will have extra charges if you need to upgrade the slab. Most builders offer M class. This can pump us the site costs by $6k to $12k. Re: Site costs!!! anyone building/built in Rose Grange Tarneit?? 3Oct 26, 2009 3:59 pm Eve Dweller From what I understand many areas out west are requiring H or even P class slabs. Even a fixed price site cost will have extra charges if you need to upgrade the slab. Most builders offer M class. This can pump us the site costs by $6k to $12k. Thanks for the reply, Eve We will need the H class slab, the first estimate we got was for $20k! Then with some shifting around on the block they've estimated around $15k. Then after talking to the engineers they may offer to lock it in at $14k for us. Does anyone know if this is reasonable? We are possibly building with M3tricon. Re: Site costs!!! anyone building/built in Rose Grange Tarneit?? 4Oct 26, 2009 8:56 pm I'd lock it in, that is a fairly good price in Tarneit I am assuming up the Leakes Road end? The land generally has a bit of fill on it and/or rock in the ground, make sure your fixed site costs include rock as well. When we were going to builder with PD our site costs where ~ $20k in Rose Grange, we ultmately changed blocks and brought in Point Cook instead but that should give you an idea. Re: Site costs!!! anyone building/built in Rose Grange Tarneit?? 5Oct 26, 2009 9:41 pm Zerosignal I'd lock it in, that is a fairly good price in Tarneit I am assuming up the Leakes Road end? The land generally has a bit of fill on it and/or rock in the ground, make sure your fixed site costs include rock as well. When we were going to builder with PD our site costs where ~ $20k in Rose Grange, we ultmately changed blocks and brought in Point Cook instead but that should give you an idea. Thanks zerosignal, that has actually helped us a lot and given us a little piece of mind. It's so hard to make some of these decisions on your own. Re: Site costs!!! anyone building/built in Rose Grange Tarneit?? 6Oct 26, 2009 10:11 pm Roz2877 Zerosignal I'd lock it in, that is a fairly good price in Tarneit I am assuming up the Leakes Road end? The land generally has a bit of fill on it and/or rock in the ground, make sure your fixed site costs include rock as well. When we were going to builder with PD our site costs where ~ $20k in Rose Grange, we ultmately changed blocks and brought in Point Cook instead but that should give you an idea. Thanks zerosignal, that has actually helped us a lot and given us a little piece of mind. It's so hard to make some of these decisions on your own. It can be very hard when you do not know, funny we're first home buyers but we have had contracts on two different blocks of land and tenders with 3 builders until we found the right one. That area is set for some major development in the future, last I read Leakes Road is destined to be a 3 lane (each way) highway/main road. We spent close to 2 years in a process with TA. It was horrible..... we got to tender, and the first cut was 50% over our budget which "they care such about meeting ". We… 18 27837 Is anyone building with Mojo and have a recent site cost tender 0 16112 Henley should give you some indication of site costs. Too many variable to give you any reasonable accuracy 1 2083 |
