Browse Forums Building A New House Re: Notes on the construction drawings - Is Builder responsbile? 5Dec 12, 2007 1:51 pm sandydubes The notes are not inlcuded in the contract or the tender. It is just mentioned on the drawings. The house is having the standard set-back as per the requirements which is 5mts. The tree is appx. 8 mts from the house. sd so they wont be doing it then... Just a case of covering their bum in case the tree causes you problems down the track when it get big I would say... Built Porter Davis "Dromana" 2007. Re: Notes on the construction drawings - Is Builder responsbile? 6Dec 12, 2007 1:57 pm 8m+ roots (plus be strong enough to damage a slab) means it must be going be a BIG tree - either that or they are just being over-cautious.
I wouldn't worry about it. Ray. Second Time 'Round Re: Notes on the construction drawings - Is Builder responsbile? 7Dec 12, 2007 1:57 pm We went through something similar with our first go with PD.
In the end, it caused us to walk away from the project. There's more detail on the blog, however the root barriers in our case were going to cost around $10k, and they were missed at tender appointment time. Just before the contract appointment the news was broken to us, and naturally we spat the dummy. Interestingly, PD didn't want to build without the barriers as they were worried about problems down the track - these trees were mature. One question - how tall is the tree? If the tree is small and far enough away, it shouldn't be a cause for concern at the moment. It sounds like they are covering themselves for the future growth of the tree. Perhaps wording like "Barriers may not be needed now (so they are not in the quote) but should be installed before the tree gets too big, otherwise the house may be affected." should have been used. Cheers perry Re: Notes on the construction drawings - Is Builder responsbile? 8Dec 12, 2007 8:33 pm If it is an immature tree a bottle of poison will be cheaper. Do not get caught removing it or poisoning it. Council hate people removing trees from nature strips. Fi has moved in!! Thanks very much! And would the landscaper/contractor generally involve the engineer or is that something the client would do? Thanks for your help 2 10025 Peter In NSW your Certifier will have a copy, and the Certifier works for you not the builder. They are your representative so just contact them and ask for a… 6 2780 How are you doing Ben? Extremely interested in hearing what you are doing or plan to do! 12 15156 |
