Browse Forums Flooring & Floor Covering Re: Timber floor and tiles in one room ? 3Oct 16, 2009 5:56 pm 'chelle We have a hand-over date...15/10...but I won't hold my breath! http://people-in-glass-houses.blogspot.com/ Re: Timber floor and tiles in one room ? 6Oct 16, 2009 6:19 pm Blog is now up - http://www.jbdave.blogspot.com/ Re: Timber floor and tiles in one room ? 7Oct 16, 2009 6:53 pm Overlay flooring is 12mm/13mm thick and can be laid directly onto the slab ( with a watreproof membrane installed) whilst tiles and bed will be around 8mm. Re: Timber floor and tiles in one room ? 8Oct 17, 2009 2:45 pm So you want floorboards generally, but tiles in the kitchen? Why? In my mind, floorboards would be preferable in the kitchen too, so why not just continue them into the kitchen? In kitchens, you can have pots & pans dropping, and tiles can crack & chip. With floorboards, they might dent, but can be filled and refinished with the rest of the floor. Grout will take some cleaning from time to time too. Another option is to have cork in the kitchen, offering some cushion, which can be much kinder on those who spend lots of time cooking etc. Its a nice resilient surface that can blend well with your hard floors. Much better than tiles in my book! But of course, its your place, so do as you wish! Ash. Re: Timber floor and tiles in one room ? 9Oct 18, 2009 1:42 pm Thanks everyone...we have decided to go with complete floorboards for the ground level. Now is between the engineered floorboards & real timber floorboards....... Re: Timber floor and tiles in one room ? 10Oct 21, 2009 8:37 am hi vincy, we are also thinking about tiles for kitchen and timber everywhere else on ground floor, but after reading this thread, I'm also thinking timber throughout. floating vs solid is our question as well. I see you are in Sydney, check this place out http://www.carpetfloorsolutions.com.au We went there on Saturday and the guy spent 20minutes explaining the differences even though I am a year away from needing the timber Their prices are competitive too, imo jim Re: Timber floor and tiles in one room ? 11Oct 21, 2009 10:39 pm Thanks Jim, I will check out the place..... Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16398 They make the room much easier to clean for one, reflect more light (if light colour tiles are used), and you dont end up with dust on the top edge of tiles (cause most… 3 9896 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 950 |
