Browse Forums Home Theatre & Automation Re: HT Equipment Advice 4Sep 21, 2009 7:28 pm I also agree entirely. I just purchased a run-out Denon model cheaper than what the model below was selling for on sale at the same time from the same store in Carlton. The discount on the model I bought was around 27% so let your fingers do the typing and hunt out a bargin. I think Rod may agree with me here, but it's better to sink a bit more of your budget into the sound to give you a greater sound stage which will last you for years to come. Where as projectors, both DLP and LCD will be forever changing in both price and advancements in the years to come. What is great, fantastic and really cool now will be old hat in 12mths time. Well maybe not 12mths, but I think you get the idea. PD Hayman 34 H1 Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=29460&start=0 Blog http://miazfolly.blogspot.com Tiles 25/3/09 Colors 6/4/09 Tender 7/5/09 Contract 28/5/09 Land 16/11/09 Re: HT Equipment Advice 5Sep 21, 2009 8:01 pm Rob&Kat Hi Rod & others, I think I have sorted out what equipment i'm going to use, just asking for your thoughts / ideas ? Firstly my HT Room is 4.23 x 4.23 (I know a square, but I will deal with that issue later). Equipment: Denon AVR-2310 Benq W5000 with 95" or 105" fixed screen Mission M34 Speakers maybe? Any comments welcome. erm- just so you know, you can't really 'deal with the room problem later'... it will always be a square room! lol.. In terms of your speakers, don't make a decision until you've listened to a number of similarly priced options. Take a few of your favourite cd's to find what 'sound' you like. In terms of your projection screen - what is your viewing distance? This will help you determine what size screen you should have. In terms of your reciever - do you want it to be 'future proof'? If so, you probably want one that has the latest codecs - or at least has HDMI if you have a device (like a ps3) that can do the HD sound encoding internally.... Re: HT Equipment Advice 6Sep 22, 2009 12:08 pm Jila, you are spot on with trying to get a runout model, I have been keeping my eye out for them, but you do need to have an idea of what you want, Then I can compare any bargins I find to make sure the unit has more or better features than what I want. At the moment I'm not settled but I do require the extra zone control. Rod, I heard these at one of your favourite stores BPP and they sounded great. I have yet to price them independly to see what range they are in. Thank you all for your help and comments, seems like I have a little more research to do. Building the Henley Ascot 483: Handover 1/4 Re: HT Equipment Advice 7Sep 22, 2009 12:52 pm Rob&Kat Jila, you are spot on with trying to get a runout model, I have been keeping my eye out for them, but you do need to have an idea of what you want, Then I can compare any bargins I find to make sure the unit has more or better features than what I want. At the moment I'm not settled but I do require the extra zone control. Rod, I heard these at one of your favourite stores BPP and they sounded great. I have yet to price them independly to see what range they are in. Thank you all for your help and comments, seems like I have a little more research to do. If you require the multi-zone feature for your receiver, that will probably drive you into the higher end models. Just afew notes of warning on multi-zone, I have a multi-zone Denon (2807) : - the second zone uses up two of the speaker outputs. This means you can have two zones 5.1 and 2.0, but if you really want 7.1 in the main zone area you may need to check that your multi-zone feature can really support this as well as a second zone on 2.0. I *think* some of the newer receiver do this now. - the second zone only supports an analogue source input. So, for example, from my DVD player I have a digital out on to the receiver AND an analogue out to the receiver. There are no sync issues if I play both zones at the same time. However, some DVD players may not drive both a digital and an analogue out at the same time. ... just some things to be aware of as things are not always as they seem and you discover this stuff by trial and error. I'm certain that the sales people at the time would not have been aware of that second limitation. I think it is a limitation in the processing power of the onboard DSPs (can't decode two digital sources at the same time), so the second zone falls back to analogue ONLY. Re: HT Equipment Advice 8Sep 22, 2009 1:08 pm Jila, I'm only puttign 5.1 in the HT as I don't think there is enough room for another set of speakers to make it 7.1, so therefore the other 2 will run out to the Rumpus & Alfresco, used for music. Building the Henley Ascot 483: Handover 1/4 Re: HT Equipment Advice 9Sep 22, 2009 1:36 pm Rob&Kat Jila, I'm only puttign 5.1 in the HT as I don't think there is enough room for another set of speakers to make it 7.1, so therefore the other 2 will run out to the Rumpus & Alfresco, used for music. in-wall or in-ceiling speakers for the rear or side channels in 7.1 could free you up some space.... Re: HT Equipment Advice 10Sep 22, 2009 10:15 pm Rob&Kat Jila, I'm only puttign 5.1 in the HT as I don't think there is enough room for another set of speakers to make it 7.1, so therefore the other 2 will run out to the Rumpus & Alfresco, used for music. If all this info isn't enough, don't forget when you ask for a demo of your fav CD's, to get them to play them in true stereo. This will expose any weaknesses in the main speakers, such as being to heavy in the bass or having to be driven to hard so you actually hear everything on the CD and at what volumes. To many store displays use Neo 6 or similar to give your CD a greater sound-stage. It might not be much, but it could make the difference in your desicion. Happy hunting PD Hayman 34 H1 Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=29460&start=0 Blog http://miazfolly.blogspot.com Tiles 25/3/09 Colors 6/4/09 Tender 7/5/09 Contract 28/5/09 Land 16/11/09 Re: HT Equipment Advice 11Sep 23, 2009 2:25 pm Rob&Kat Jila, I'm only puttign 5.1 in the HT as I don't think there is enough room for another set of speakers to make it 7.1, so therefore the other 2 will run out to the Rumpus & Alfresco, used for music. Awesome. That's the same setup that I have. If you are at framing stage - you might want to get in and run your speaker cable for all of that. It will save you a world of pain later on. Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 19017 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 7069 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7117 |
