Browse Forums Windows & Doors Re: Internal Sliding Doors 13Nov 25, 2007 12:41 pm I would have though that it is possible to have the light switch beside the door.
Doing some rough calculations, if the wall is 100 mm wide and the doors is 40 mm wide, that's 30 mm each side. With 13 mm plasterboard that's still 17 mm for the wiring. Allowing 5 mm clearance between the wiring and the door that 's still 12 mm for the wiring, which I would have though was plenty. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Internal Sliding Doors 14Nov 25, 2007 5:56 pm Wow, cookie, that room looks just like you!!!!!!!!!!
All you need is some blue fur cushions and maybe a throw!!!! Re: Internal Sliding Doors 15Nov 25, 2007 6:02 pm **Phoenix** Wow, cookie, that room looks just like you!!!!!!!!!! All you need is some blue fur cushions and maybe a throw!!!! Hehehe. I used to live in that room. Re: Internal Sliding Doors 16Nov 25, 2007 6:25 pm Was that your theatre? What colour is the new room going to be????? Re: Internal Sliding Doors 17Nov 25, 2007 7:46 pm **Phoenix** Was that your theatre? What colour is the new room going to be????? Yep that was the theatre. We'll stick with lighter boring colours like whites and light greys in the new house as we won't be having a projector, so we don't need a darker room. Re: Internal Sliding Doors 18Nov 25, 2007 10:19 pm Cookiemonster Keep in mind that you can't have light switches on the wall where the door slides into the cavity. Contact Alma Building Products. They make cavity sliders that allow for electrical wiring. So you can have the light switch where you want it. Okay, then the choice is really about the build quality of the door itself which means the brand name. Sorry I can't recommend one or the other so best to rely on comments… 5 3287 we have a standard size and often we have a lot of variety to choose 0 3582 We are looking for sliding doors which are 5 metres tall. There are a few European options. Any manufacturers in Australia or distributors? 0 5046 |
