Browse Forums General Discussion Re: Need help/advice on how to build some walls for an offic 3Nov 21, 2007 6:05 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Need help/advice on how to build some walls for an office 5Nov 21, 2007 7:21 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Need help/advice on how to build some walls for an office 6Nov 21, 2007 8:21 pm How high is the wall and how long?
If its under 3.0m you can use 70x35 pine framing ( about $1.70/metre) You cheapest sheeting option would be some 3mm mdf (about $8 for 2400x1200) which you can leave or put a coat of paint on. The sheets won't be particulary strong but will do the job. Hi VK, Think it's worth investing time in an Owner Builder course to equip you with basic knowledge on Australian Building Industry and its regulations. Also, I suggest… 11 23843 My home office is hot with computer equipment running virtually 18 hours a day. When it gets unbearably warm I simply step out of my door into the living area which is… 0 5182 XCEM Alpha flooring seems to relatively new and I could not found any reviews. Have you or someone you know have used it and would recommend over other subfloor options?… 2 7635 |
