Browse Forums Windows & Doors Re: Scratched Windows 8Aug 22, 2009 6:32 pm Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Scratched Windows 10Aug 22, 2009 7:01 pm only our front windows have a green "thick glad wrap type" plastic material on them, a couple of others had signs on them saying attention: brickies..... attention: others etc..... (basically be careful), maybe they arrived this way, but had I thought they would get scratched after installation I would have taped some wrap on them myself, I hope I don't get any grief from the builder and I guess the only way to rectify would be to replace the glass as I can't imagine there would be any way of getting the scratches out like you would on a car. Re: Scratched Windows 11Aug 22, 2009 7:49 pm When you see the way many of the window's are dumped on-site it's no wonder they appear with scratches and dents when installed. I always wondered why they do not at least glad wrap the windows when they literally drop them off in the dirt. Wouldn't this be cheaper for them than a builder ringing up requesting replacements. would it be fair to say Ed that in many home estates with so much dust/dirt around that as you say time cleaning comes it's the dirt that scratches the window? Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Scratched Windows 12Aug 23, 2009 9:57 am ozzroo When you see the way many of the window's are dumped on-site it's no wonder they appear with scratches and dents when installed. I always wondered why they do not at least glad wrap the windows when they literally drop them off in the dirt. Wouldn't this be cheaper for them than a builder ringing up requesting replacements. would it be fair to say Ed that in many home estates with so much dust/dirt around that as you say time cleaning comes it's the dirt that scratches the window? Hi Ozzroo Ours are all wrapped. Windows are mostly damaged during construction with render or mortar splashes and someone wipes the stuff off when it's wet or the cleaner tries to scrape it off later. The method always leaves a tell tale pattern. It's important that the windows arrive on site when the house is ready, any earlier and they sit around and are, as you say, prone to damage. Never use a blade on glass, never use any hard sharp edge on toughened glass... you are likely to scratch it. Toughened glass has a logo on the corner (all doors are toughened). Toughened glass has a surface covered in "fines" which can be picked up on a blade and it's the fines that scratch glass. If you clean glass make sure the cloth is perfectly clean. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Scratched Windows 13Aug 23, 2009 2:02 pm Its not going to help you much now but i got all the windows covered in scratch protective goop. The whole house cost $150. Seems, as usual, the HIA guideline is leaning heavily towards protecting the builder. 10mm long fracture or chip acceptable??? I wonder if the same stuff they use to repair chips in windscreens will reduce the appearance of scratches/chips in house glass? Re: Scratched Windows 14Aug 23, 2009 7:19 pm wake_me Its not going to help you much now but i got all the windows covered in scratch protective goop. The whole house cost $150. Seems, as usual, the HIA guideline is leaning heavily towards protecting the builder. 10mm long fracture or chip acceptable??? I wonder if the same stuff they use to repair chips in windscreens will reduce the appearance of scratches/chips in house glass? As mentioned before I haven't spoken to the SS yet so I shouldn't be a pessimist BUT if I have any problems with the builder replacing I guess I could also use something like the following, I shouldn't cross that bridge before I get to it though! Re: Scratched Windows 15Aug 23, 2009 7:31 pm Some of our windows came with the plastic film over frame and glass. Others didn't have it and have scratches on the frame. I've raised this with our SS and he's looking into it. I certainly don't want touch up paint - will just look tacky. After 4 years - we're in! Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.… 7 10539 Hi, I'm planning to build a new house and wanted to get some feedback on the different window designs for a master bedroom. Our bedroom is north facing and the bed will… 0 4583 I’m restoring all my 40yr old windows and I want to install seals around the casements. I’ve sanded back and oiled the frames with sikkens. My plan is to box up inside… 0 6551 |
