Browse Forums Feng Shui Re: street drain infront of block good feng shui? 5Aug 09, 2009 3:11 pm Do the hard jobs first. The easy jobs will take care of themselves. - Dale Carnegie Re: street drain infront of block good feng shui? 6Aug 11, 2009 11:47 am I'm worried about all the negative energy coming from my electricity supplier, so i'm going to have the cables installed in the sewerage pipes so it will flow away to where it belongs Re: street drain infront of block good feng shui? 7Oct 03, 2009 11:54 pm Lifestyle_Living Hi everyone, I was wondering if there is a street drain along the road adjacent to the kerb infront the house consider as good or bad feng shui? I was told various opinions, as water flow under into your block which good feng shui as oppose to water get carry away from block by the drainage. Thanks If it drains directly in front of the house, it is terrible Feng Shui. However if the drainage is at the following positions in relation to the middle point of the house it is fine. These positions are the North east, South west, North west and South east. These four positions in Feng Shui is called "water mouth" and the outgoing water is preferred to pass one of these areas. Cheers! Lok Tin Re: street drain infront of block good feng shui? 8Oct 16, 2009 8:21 pm Loktin Lifestyle_Living Hi everyone, I was wondering if there is a street drain along the road adjacent to the kerb infront the house consider as good or bad feng shui? I was told various opinions, as water flow under into your block which good feng shui as oppose to water get carry away from block by the drainage. Thanks If it drains directly in front of the house, it is terrible Feng Shui. However if the drainage is at the following positions in relation to the middle point of the house it is fine. These positions are the North east, South west, North west and South east. These four positions in Feng Shui is called "water mouth" and the outgoing water is preferred to pass one of these areas. Cheers! Lok Tin I just looked at my floorplan and found there's storm water pit in front of my house (not directly in front of the house, it's on the street footage). Is this considered terrible Feng Shui too? If it is, does anyone have any advice how to block the bad energy? Cheers. Re: street drain infront of block good feng shui? 9Oct 21, 2009 12:56 am Lifestyle_Living Hi everyone, I was wondering if there is a street drain along the road adjacent to the kerb infront the house consider as good or bad feng shui? I was told various opinions, as water flow under into your block which good feng shui as oppose to water get carry away from block by the drainage. Thanks generally, nothing bad. unless 100% of the time, it's stinking sewer water that flow thru....thats bad. depending on your terrain - lets say your house sits on a flat ground. If the drain flow from front left to front right - it's considered average fengshui. but if you have a drain on the left of your house - separating you from your neighbour on the left. Plus - the water flow from back(back of the house) to the front. This is the kind of house I would look for. because it has fullfilled one of the important fundamentals of a good fengshui house. PS: a good FS house depends on a lot of criterias, not just the above Re: street drain infront of block good feng shui? 10Oct 21, 2009 12:59 am star_panorama I just looked at my floorplan and found there's storm water pit in front of my house (not directly in front of the house, it's on the street footage). Is this considered terrible Feng Shui too? If it is, does anyone have any advice how to block the bad energy? Cheers. nope. define bad energy - did you engage a fsm and he/she told you that? Re: street drain infront of block good feng shui? 11Oct 21, 2009 10:29 am snipfer star_panorama I just looked at my floorplan and found there's storm water pit in front of my house (not directly in front of the house, it's on the street footage). Is this considered terrible Feng Shui too? If it is, does anyone have any advice how to block the bad energy? Cheers. nope. define bad energy - did you engage a fsm and he/she told you that? I'm not too sure what bad energy in this case :p I was just reading this thread about how bad fengshui it is to have the drain in front of the house. Re: street drain infront of block good feng shui? 12Oct 21, 2009 11:33 am star_panorama I'm not too sure what bad energy in this case :p I was just reading this thread about how bad fengshui it is to have the drain in front of the house. if you have a nuclear power plant(with cracks) in front of your house - yes thats really BAD ENERGY dont worry too much. Just make sure that the drain does not clog with rubbish. Keep your house clean and tidy - and you got a good fs house. Hi all. I'm thinking of installing an electric gate in front of this street front villa (link below). The gate would be between the bush on the left and the letter box on… 0 2778 Thanks! I'm spoke to the builder I'm not sure if this is all true but basically went along the lines of they considered all options and if I was to compact and fill it… 2 7307 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4539 |
