Browse Forums General Discussion Re: Raising Queenslander which is already built under 2Nov 04, 2006 5:27 am have a look at https://forum.homeone.com.au/viewtopic.php?t=475 Re: Raising Queenslander which is already built under 3Nov 16, 2006 3:44 pm Unfortunately we have already built in under the house - with walls for new laundry,sliding doors for rumpus, study, etc. At the time we couldn't afford to raise the house - big mistake, false economy. [probably have to start from scratch, that is demolish all downstairs, raise the house and start again. Would like to hear from anyone that has had to do that. Re: Raising Queenslander which is already built under 4Nov 17, 2006 4:24 pm I can't see how it would be possible to lift a house without demolishing the ceiling and most if not all of the walls. When our house was lifted they ran a few big beams underneath the full length o the house, and then lifted those with hydraulic jacks. Your existing ceiling and walls are going to get in the way.
The other problem you might run into is approvals. The inspector will want to inspect the footings before the slab goes in, and the frames before the cladding goes on, which would be a bit hard in your case. Is your existing work approved? I suspect not, if there is insufficient height. Starting again is probably going to be cheaper than trying to work around what you have. If your patio is going to be 35 sqm then that's going to need Council Approval. The fact that they previously approved your 25sqm patio will be irelevant 1 5818 I want to build a bigger driveway (without a nature strip) than has been approved under my CDC. I’ve also had a DA approved to build a deck. It looks like I can do this… 0 5001 Hi All, about to commence a bathroom renovation and need some advice on subfloor works. Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to… 0 6087 |
