Browse Forums Building A New House Re: Doing own electrical fittings 2Nov 12, 2007 6:41 am I would be asking the 'friend' who is going to sign it off first. Some have a 'limited licence' where you can only do your own work.
There's a bit of paperwork involved now, and if anything goes wrong it comes back on your friend who signed it off. It would also depend on your builder - some won't let anyone except their own subbies on site, others are more relaxed. I really can't see you saving that much unless the friend is working for free. I posted a while back where myself & a mate ran all the cabling in his new house, under instruction from the sparky, who was running short on time & basically wanted to walk off the partly finished job on a saturday (OB job with a plasterer coming the following monday). He did all the paperwork side of things, marked where everything had to go, left us to it & came back sunday arvo to check it off. All up I think the saving was about $800 in labour cost, which really doesn't seem worth it for 2 of us doing 2 days work in the heat. Re: Doing own electrical fittings 3Nov 12, 2007 7:36 am $800 is still $800 saved.
Unless the friend is an A grade he can't sign it off. And most sparkies won't touch anyone else's work if the friend falls through for some reason. I ran all the wiring in my extension, and luckily the old sparky I know was happy to fit it off for me and do the certificate. He did inspect the stuff I ran under the house, mentioned I needed more cable mounts and was happy with it. I tried a number of other sparkies and they all said they had to run the wiring before they sign it off....more money in the pocket for them I guess... Re: Doing own electrical fittings 4Nov 12, 2007 8:50 am Looking at the safe side, business is business, I would pay your friend $ (probably at a discount??!!), to get him to do all the work, and provide all proper documents. In case there's any requirement from council or whoever, or in case you need to sell the house X years later and your builder's paper only covers 50% of the electrical workand you get problem with the rest... Re: Doing own electrical fittings 5Nov 12, 2007 9:31 am Legally the sparky must have a current contracters licence. My next door neighbour although a (highly) qualified electritian doesn't actually have contractors licence as he is employed by a company so doesn't need it. The contractors licence is different from an electrical licence.
It still worked out well for me though - I rewired the entire house from scratch and including cable/light fittings and all switches/power points etc. cost me a total of $800!! Re: Doing own electrical fittings 6Nov 13, 2007 5:54 am Thanks for your replies. Getting hubby and friend (who is a licenced contractor with experience) to do it may be more complicated and time consuming. We may see if friend can do it for small fee with hubby assisting. The DIY project can be broken into two major steps. Planning and Design and Construction. Both of these steps are as important as one another to ensure you give… 0 5175 Hi group, have some damage to the door frame and skirting board. It's a side door to the laundry area. Only has a security door. I had a termite inspection (note drill… 0 5059 0 2024 |
