Browse Forums General Discussion Re: ******* Building Inspection?? 10Nov 05, 2007 6:35 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: ******* Building Inspection?? 15Nov 09, 2007 10:26 am Just to let you all know, you cant tell if a wall is asbestos just by looking at it, or knocking on it with your knuckles. The only way is to do a lab test for asbestos (labs that do these tests can be found in the yellow pages)
If in doubt over an old house, I'd get the tests done. Building a Jandson Espirit in Pennant Hills "What is the use of a home, if you haven't got a tolerable planet to put it on?"Henry Daniel Thereau Re: ******* Building Inspection?? 16Nov 09, 2007 11:14 am If it's bare, in some cases you can tell. If you can see the back of it, again sometimes, you can tell. Also, the age of your home will give you a fair indication if it would have been used or not.
The stuff at my place had small blue flecks through it. Hence, blue asbestos. Everyone pelase note, asbestos itself is not dangerous. It become an issue once you disturb it and breathe the dust. If it is there and doesn't need to be moved, leave it alone. The eaves the front of my house are asbestos and seeing as I have no plans to drill, break, disturb or eat any of it, I am not the least bit worried about it. Re: ******* Building Inspection?? 17Nov 09, 2007 11:24 am Al If it's bare, in some cases you can tell. If you can see the back of it, again sometimes, you can tell. Also, the age of your home will give you a fair indication if it would have been used or not. It's not hard to tell the asbestos walls in our house apart from the masonite walls... the asbestos walls have a slight textured pattern to them, are nailed in with flat nails and sound completely different to the rest of the walls. Further to this, it's not hard to remove a power point which easily identifies it... Quote: The stuff at my place had small blue flecks through it. Hence, blue asbestos. Ours has white flecks I believe?? Quote: Everyone pelase note, asbestos itself is not dangerous. It become an issue once you disturb it and breathe the dust. If it is there and doesn't need to be moved, leave it alone. The eaves the front of my house are asbestos and seeing as I have no plans to drill, break, disturb or eat any of it, I am not the least bit worried about it. I'm with you. Our eaves are 60 years old and still far better than those in most 10 year old houses. Asbestos is good stuff if undisturbed. The reason we are removing the internal asbestos is that we are carrying out substantial renovations, involving only the rooms containing asbestos (isn't this typical). The roof was in a bad state and had to be replaced, regardless of material. But the eaves will stay. On that note, the eaves are posing quite a problem for us. The paint is peeling off them and given that you can't sand, waterblast or scrape the asbestos eaves for ease of preparation, we will probably end up using a product called "Peel Away" in order to remove the paint and start afresh with good undercoating etc. Anyone else have any ideas? My neighbour reckons his painters just came in and sanded their eaves - always nice to know. Cheers, Lotte you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5543 i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 99154 Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6868 |
