Browse Forums Building A New House Re: Using Rainwater from our rainwater tank 2Nov 04, 2007 1:54 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Using Rainwater from our rainwater tank 3Nov 04, 2007 2:04 pm You mean bore water Michelle?
And yep +1 on the 'go for your life' - its your water... just don't get beat up by someone thinking you are doing the wrong thing Re: Using Rainwater from our rainwater tank 4Nov 04, 2007 2:10 pm Yes, thanks for that, been a big day!!! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Using Rainwater from our rainwater tank 5Nov 04, 2007 2:12 pm parker You mean bore water Michelle? And yep +1 on the 'go for your life' - its your water... just don't get beat up by someone thinking you are doing the wrong thing How bad was that!!!! Poor old guy….. but he got his own back…..for a minute!!! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Using Rainwater from our rainwater tank 6Nov 04, 2007 5:22 pm If your mains water is hooked up tom your tank( ie for grey water), restrictions under water stages still apply. If you hove no mains hoocked up to your tank, you can wash your car in the middile fo a 40 degree day in the ddile of Telstra Done, and its perfectly legal. Adrian B Re: Using Rainwater from our rainwater tank 7Nov 05, 2007 8:02 am I am fairly sure that bore water cannot be used at any time in Perth. From memory, it can only be used in the evenings. Make sure you check if in any doubt - just call your local water board. Re: Using Rainwater from our rainwater tank 9Nov 05, 2007 7:33 pm Folks, just becasue it is bore water - have you had a thought about how it got there in the first place.?
If it's not raining from above - it isnlt soaking into the ground and filtering through the soil into the aquafier to become bore water........ I don't care if it's greywater, rainwater, borewater or filtered tap water - we can't just willy nilly waste it. Use it as required - but don't waste it. Steve Re: Using Rainwater from our rainwater tank 10Nov 05, 2007 7:59 pm we have had water restrictions placed on bore water in WA you can now only use between 6pm and 9am and depending on where you are some can only use bore water on their rostered sprinkler days.
But why do people water in the middle of the day, especially in summer , it just evapourates anyway Building again . . with Redink Pre-start 04/12 Keys - 03/13 Finishing off. . . Painting/Floor Tiles/Carpet - 04/13 Walk In Robe/Lighting/Blinds and Moving 05/13 Gates/Front Landscaping / Pool 05/13 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31287 Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 31170 Broker here - legislation says that every true broker must put the clients best interests before theirs so in theory they must offer you the best options for you on their… 2 46019 |
