Browse Forums Ideas Box Re: How to use the Quote button? 11Jul 13, 2009 7:29 pm [quote]only thing is, it doesnt say who the quote is from but that is usually obvious in the context of the thread[/quote] did it work helyn? nope, thanks anyway. I followed your instructions directly. www.themaxbuild.blogspot.com forum.homeone.com.au/viewtopic.php?f=31&t=20717&start=300 www.leahspaperpassion.blogspot.com Re: How to use the Quote button? 12Jul 13, 2009 7:31 pm [quote="themax"][quote] only thing is, it doesnt say who the quote is from but that is usually obvious in the context of the thread [/quote] did it work helyn? nope, thanks anyway. I followed your instructions directly.[/quote] [quote="themax"]did it work helyn?[/quote] I'VE TAKEN UP TOO MUCH CYBERSPACE ALREADY.... www.themaxbuild.blogspot.com forum.homeone.com.au/viewtopic.php?f=31&t=20717&start=300 www.leahspaperpassion.blogspot.com Re: How to use the Quote button? 13Jul 13, 2009 7:34 pm click QUOTE Locate your cursor on the next line or better still, 2nd line down AFTER the quoted section. Then start typing your response. No need to click on anything else. SUBMIT Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: How to use the Quote button? 14Jul 13, 2009 7:44 pm Thank you all, but until there is a QUOTING FOR DUMMIES, I give up. I tried it Southies and it didn't work. Thank you for your patience www.themaxbuild.blogspot.com forum.homeone.com.au/viewtopic.php?f=31&t=20717&start=300 www.leahspaperpassion.blogspot.com Re: How to use the Quote button? 15Jul 13, 2009 7:49 pm Quote: only thing is, it doesnt say who the quote is from but that is usually obvious in the context of the thread did it work helyn? nope, thanks anyway. I followed your instructions directly. works for me....... All quotes must start with "[ quote] and end with [/quote ]" or they wont work..without the spaces in the brackets. Re: How to use the Quote button? 16Jul 13, 2009 7:57 pm themax, when I clicked QUOTE at the bottom of your post, this is what my screen then looked like : Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hope you can see it . THen all you do is locate your cursor a couple of lines down below the quoted lines & start typing your response. When you're done.......you SUBMIT. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: How to use the Quote button? 17Jul 13, 2009 8:00 pm Quoted lines have to have the Quote: in front and then ' OK so that didn't work. Try again........ the word 'quote' must be in brackets before a quote. the word 'quote' with a forward slash before it, must be in brackets at the end of a quote. Is that any better? This is getting complicated........ Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: How to use the Quote button? 18Jul 13, 2009 8:03 pm [quote="Southies"]Quoted lines have to have [quote] in front and then [/quote] at the end of the quote. The only difference between the 2, is the forward slash which must be always at the end of a quote.[/quote] Hold your breathe, here goes...submit (I say with my fingers crossed and eyes closed). Southies you have gone to so much trouble, I hope I don't let you down...... www.themaxbuild.blogspot.com forum.homeone.com.au/viewtopic.php?f=31&t=20717&start=300 www.leahspaperpassion.blogspot.com Re: How to use the Quote button? 19Jul 13, 2009 8:04 pm [quote="themax"][quote="Southies"]Quoted lines have to have [quote] in front and then [/quote] at the end of the quote. The only difference between the 2, is the forward slash which must be always at the end of a quote.[/quote] Hold your breathe, here goes...submit (I say with my fingers crossed and eyes closed). Southies you have gone to so much trouble, I hope I don't let you down......[/quote] test number 654532736 www.themaxbuild.blogspot.com forum.homeone.com.au/viewtopic.php?f=31&t=20717&start=300 www.leahspaperpassion.blogspot.com hey there! 😊 so, it’s kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20979 I was being kind to the builder. With the amount charged for the upgrade the builder is probably charging closer to 100% margin. There are a few variables as I… 5 14359 I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12485 |
