Browse Forums Landscape & Garden Design Re: Do I need a retaining wall? 4Jul 04, 2009 11:58 pm Where you are coming from is where you are going to... Re: Do I need a retaining wall? 5Jul 05, 2009 12:15 am my engineering says that i need a retaining wall on one side, get your builider to send you the engineering report Re: Do I need a retaining wall? 6Jul 05, 2009 12:07 pm buildingwithhamra my engineering says that i need a retaining wall on one side, get your builider to send you the engineering report You will still need another engineers report for the retaining walls and more than likely council approval. This is something I have learnt pretty quickly from experience - we are back at council for the 3rd time in as many weeks with retaining wall approvals. The original approval - on the house plan da - had to be revisited as we hit rock. We are also having to build 2 pretty big retaining walls now, rather than in 12 months as we hoped, due to the rock! JL Re: Do I need a retaining wall? 7Jul 05, 2009 8:40 pm Actually, we don't want a large retaining wall, engineered or not. I saw WallMaster at the latest HIA Home Expo show, and I'm strongly considering creating a layered/terraced area. Essentially, we just need a little bit of lawn-type space for the dog bathroom. Re: Do I need a retaining wall? 8Jul 05, 2009 9:20 pm Isn't that still a retaining wall though? I clicked on the link you provided. JL Re: Do I need a retaining wall? 9Jul 05, 2009 9:30 pm houseofl Isn't that still a retaining wall though? I clicked on the link you provided. Yes, but I can keep each level around 615mm, so completely under the 1m "requires engineering" requirement. Re: Do I need a retaining wall? 10Jul 05, 2009 10:01 pm Aha! Well, it certainly looks nice. Good luck! JL Re: Do I need a retaining wall? 11Jul 06, 2009 9:09 am it depends on what you want to do with the area Djelibeybi like the others have suggested, if its a metre or so you will need engineering but you could do 2 smaller walls and use the top as a garden, or put gravel across with some plants or pots to make it look nice, or have the top as a path and the middle as a small garden if you did one large wall you couldnt really use the area unless you added steps, the 2 smaller retained area's would be nice in that spot Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: Do I need a retaining wall? 12Jul 06, 2009 10:41 am billdsl like the others have suggested, if its a metre or so you will need engineering but you could do 2 smaller walls and use the top as a garden, or put gravel across with some plants or pots to make it look nice, or have the top as a path and the middle as a small garden Yeah, this is what I'm thinking: Have the top-most level be about 1m wide, to create a gravel path all the way around the house. Then have a 0.5m - 1m wide 2nd level which will have plants and things. Then the bottom/lowest level would be about 2.5m-3m wide, which includes the easement of 2m. So, that bit would be grass/lawn type stuff for the dogs. Re: Do I need a retaining wall? 13Jul 06, 2009 3:26 pm that would work and be quite easy to put into place, and no need for engineering either all round win Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Building Standards; Getting It Right! Hi everyone, a contractor build a "retaining wall" for me and after 3 months there was a crack. They "repaired" the crack by adding an expansion joint where the crack… 0 2472 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 7066 Not sure what council area you are in. Some LGA's allow zero lot retaining walls. This usually occurs in greenfield developments but not often in established areas. You… 1 9131 |
