Browse Forums Home Theatre & Automation 1 Apr 02, 2009 8:54 pm Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. ![]() >>> ... http://retreatspring.blogspot.com Re: Hills Home Hub or own cabling 2Apr 03, 2009 8:33 am ---------------------------------------- Building the PD Lisbon 24 http://www.porterdavis.com.au/#homeviewer/lisbon/24 Blog of our progress. http://lisbon24.blogspot.com/ Homeone build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=28665 Re: Hills Home Hub or own cabling 3Apr 03, 2009 10:05 am Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Hills Home Hub or own cabling 4Apr 03, 2009 12:02 pm Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. ![]() >>> ... http://retreatspring.blogspot.com Re: Hills Home Hub or own cabling 5Apr 03, 2009 2:41 pm Our Blog! http://cityplantation.blogspot.com | Building the Havana 485 with Plantation Homes (Henley) Re: Hills Home Hub or own cabling 6Apr 03, 2009 3:41 pm Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. ![]() >>> ... http://retreatspring.blogspot.com Re: Hills Home Hub or own cabling 7Apr 04, 2009 7:54 am Licenced Sparky and Data Cabler If "The Data Guys" is too long to type, TDG will do. Re: Hills Home Hub or own cabling 8Apr 04, 2009 9:18 am Our Blog! http://cityplantation.blogspot.com | Building the Havana 485 with Plantation Homes (Henley) Re: Hills Home Hub or own cabling 10Jun 23, 2009 5:10 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Hills Home Hub or own cabling 11Jun 23, 2009 5:19 pm Thanks. But generally, what do you think about the costs? I have read in other posts that some people are saying $1600 smartwiring with 8 data points is considered expensive. But my wiring only has (1) data point and 3 phones and 2 tv, (total of $550 for these points) and I still don't know whether they will include star serve or not. The only description in their estimate is "Integrator - $1390 for star serve". I have tried asking them but there is no reply from them yet. Re: Hills Home Hub or own cabling 12Jun 23, 2009 6:04 pm to be honest unless you indicate which area you are in i can't help on prices but also why on earth are you going with such a basic package / set up in this day in age esp with just "phone" points where setting up even a basic smart wired house is so much more flexible for down the track.... even a house plan would help too as then i could advise you on what you should be putting in instead a "basic" package Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Hills Home Hub or own cabling 13Jun 23, 2009 8:49 pm Thanks. I am building in the Hills area in Sydney. In terms of design, after reading up on smartwiring in the last couple of days I will definitely want to setup a network with at least one data point per room and the rumpus and living area as well. My main concern now is how can I make sure that my builder uses the correct cables and doing all the necessary things in order to make way for the installation of the ONT by Telstra Velocity. It is hard to get any response from the builders and their itemized list of electrics does not specify any description of cables or starserve to be used. And of course, there is the "costs" issue. Is it advisable to try to find someone else to do the smartwiring part (ie. phones, TV and data)? and let the builder take care of only the electricity wiring part. Is this a common/acceptable practice? From reading some of the posts, it seems that getting another contractor to do work on site is not an easy thing to achieve. Is that right? Re: Hills Home Hub or own cabling 14Jun 23, 2009 11:13 pm another member on here called TDG is a cabler in your area... personally i see no point in skimping in this or any area of the build even if you just get conduits install or predill with pull wires you can do what ever after hand over bya data cabler Iit is worth asking your builder about third party tradies... esp if you are particular about ... Your House bare minimum for me would be two Cat6 "data" and one RG6 (quad shield coax) "TV" points in each "main" room where you might put a TV or Computer Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Thanks again Simeon for being so elaborate. Appreciate it. Its gives us a very idea. Kind Regards 4 4332 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 22414 ![]() We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 18855 |
