Browse Forums Windows & Doors Re: Apart from cost, any downside in using toughened glass? 12May 19, 2009 12:18 pm
Re: Apart from cost, any downside in using toughened glass? 14May 20, 2009 8:07 pm Change is what we need! Can we? YES WE CAN!!!!! Re: Apart from cost, any downside in using toughened glass? 19May 21, 2009 3:23 pm Miglas Windows Argon should be possible soon for less than 50$ if you have the right supplier. If by this you mean the extra for Argon, it should be less than $10/m2. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Apart from cost, any downside in using toughened glass? 20May 21, 2009 3:36 pm ed @ EcoClassic Miglas Windows Argon should be possible soon for less than 50$ if you have the right supplier. If by this you mean the extra for Argon, it should be less than $10/m2. Ed Beauty. My sliding windows are just under 4 m2 each, so I'll be able to upgrade each of the 9 sliding windows for less than $50 each. This should bring the 8 mm gap for the sliding windows up to the same thermal performance as the other windowes which have a 12 mm air gap (from the graph you provided Ed). It's all coming together Thanks for your help Ed, Kris, windowexpert, et al. Demolition August 2009, Construction Started September 2009, Completed December 2010 Approvals are covered in the cost we are paying to the pool company. The only thing stated in our home build contract for the additional cost is engineering support. … 3 7471 Broker here - legislation says that every true broker must put the clients best interests before theirs so in theory they must offer you the best options for you on their… 2 46185 0 2174 |
