Browse Forums Home Theatre & Automation Re: Home Theatre Setup 21Oct 05, 2007 8:21 am Sorry Lee, I should have remembered you had that amp. It is a 6.1 so the 3 surround speakers are correct!
Now, according to it's specs it does A + B speakers, but also has a couple of other (multi) zones you can use. These will be line-out/pre-out outputs so you will actually need some other type of amp (each) for those zones (a simple stereo amp will suffice, or dedicated stereo power amp). This setup tends to lift the level of complication a little. You might find it easier and cheaper to get the speaker selector like above and run from your Speaker B outputs into it, then it will be able to service up to 4 other rooms (besides your theatre). We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 18856 Hi, guys! If you've built with Wisdom Homes, would you mind sharing images of your front facades once they're all rendered? I'm considering signing up with them for a wide… 0 15348 |
