Browse Forums Home Theatre & Automation Re: Foxtel pre-wiring 12Sep 24, 2008 2:28 pm 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Foxtel pre-wiring 17May 08, 2009 5:15 pm Here is some info from Foxtel on Pre-Wiring https://www.foxtel.com.au/support/Getti ... ALONEDWELL https://www.foxtel.com.au/support/Getti ... #subtopic1 Re: 18May 08, 2009 5:27 pm wakeboardandy Mr Ed Secondly, if you want to be compliant with FOXTEL HD your standard 1 x RG-6 (coaxial) cable to each room you intend to put the decoder will not do. Foxtel mandates that you will require 2 x RG-6 cables plus either a telephone connection or internet connection. The two RG-6's are needed for the high definition digital signal and the telephone/internet connection is required to order from box-office. For the communication I have used CAT-6 (CAT 5/5e will do) since I have installed a home network with an Ethernet hub and Clipsal StarServe to distribute telephone and TV. Foxtel have pretty good documentation on pre-wiring your home on their website, check it out at at http://www.foxtel.com.au/FactSheet.htm Hope this helps! If it is cable or optic fibre (like my estate) then you don't need to run 2xrg6 cables. It is only satellite you need to run that so it can pick up both horizontal and vertical signals. or you can have a centeral spot in the house where all the wiring goes to (pre wire) and then distrubute later on to which ever rooms need which even service.. for this each room would need to have 1 x RG6 and at least 2 x Cat5e/6 runs. you can get devices that work form a central location and can mix cable/ satellite and FTA into the one cable (RG6) Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Foxtel pre-wiring 19May 24, 2009 10:39 am Hi I really like this tread, the information is most valuable, in my case the TV coaxial connections is supplied by my builder and I want to know how it differ from the foxtel and satellite dish coaxial cable. I will plan to have either Foxtel or satellite dish connection in future. Can I use RG-6 (coaxial) for either of these? Cheers PS ps We've had the offer of a short term tenant whilst waiting for CDC/DA home approval and demolition for our knock down rebuild. It would achieve a pretty low rent as it's… 0 13916 The fastest thing a builder will do is bank your cheque, those systems work perfectly with lightning speed, everything else is slow burn. Just the way it is. 1 8921 Just to makea point about this, an approach that some people have found sucessful in negotiating these rises down, Is to provide some workings to the builder, specifying… 4 81903 |
