Browse Forums Windows & Doors Re: Front door windows 3May 01, 2009 8:39 pm 2011 Home Sweet Home Handover 03 September 2010 PCI 27August 2010 Plumber 20August 2010 Electrician 19August 2010 Painting 04 August 2010 Cabinets 13Jul2010 Lockup 23June Frame 20April slab 1Mar10 Re: Front door windows 5May 01, 2009 10:51 pm Anna1 Thanks Ed I know you wont be able to sleep PMAD104 attached http://www.corinthian.com.au/popups/productzoom.php?grp=ext&rnge=pmad&prod=PMAD104. I'm probably leaning toward an opening highlight, same cost do you think? It will be lowest cost as a separate window above your entry, but how will you open it? Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Front door windows 6May 01, 2009 10:58 pm Ed wouldn't that be like an old-fashioned transom (sp) ? My parents have a Victorian era home and they have transoms over their front door and french doors. They both open with a long brass rod thing that you push or pull to open / shut. Sorry if this is garbled - am off to bed now Some things are worth waiting for. Re: Front door windows 7May 02, 2009 12:30 am We are building a very modern home, can you get winders that come down the wall to a decent height? I'm just pushing the price up again aren't I! 2011 Home Sweet Home Handover 03 September 2010 PCI 27August 2010 Plumber 20August 2010 Electrician 19August 2010 Painting 04 August 2010 Cabinets 13Jul2010 Lockup 23June Frame 20April slab 1Mar10 Re: Front door windows 8May 02, 2009 7:41 am you can get electric winders, but I think it will add maybe $600... There are mechanical ones too that use piano wire... also expensive. I would invest in a pair of steps. Hi Kyton. A transom is the horizontal bar on a window (the vertical bar is called a mullion). ED "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Front door windows 11May 02, 2009 10:22 am Steps it is - thanks for your help 2011 Home Sweet Home Handover 03 September 2010 PCI 27August 2010 Plumber 20August 2010 Electrician 19August 2010 Painting 04 August 2010 Cabinets 13Jul2010 Lockup 23June Frame 20April slab 1Mar10 Building Standards; Getting It Right! AS2047 Section 6 Page 31 speaks to Construction/Tolerances of Windows and external glazed doors in buildings Check also New South Wales Guide to Standards and Tolerances,… 12 24805 I personally think pivot door are over the top, as you said a bit impractical having a small useless section and poor insulation. I’m pretty happy with a 920x 2040 with… 1 123 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9074 |
