Browse Forums Building A New House Re: Latest floor plans for Mt Barker build - ranch style (Mk 2) 3Apr 21, 2009 1:09 pm Building Upside down house in Wantirna VIC Current Stage: Procrastination... it's just all too hard.... Blog: http://thereluctantbuilder.blogspot.com/ Re: Latest floor plans for Mt Barker build - ranch style (Mk 2) 7Apr 22, 2009 11:14 pm hi there, it's looking even better again love the new open rumpus, will make huge difference to the entry way - two slimline windows in the master was a great idea, so is the double door storage to rumpus & media room...great plan! 2014 - Prepping to build the Soho 4 with Plantation homes, industrial style 2009 - Built the Brampton with Coral Homes viewtopic.php?f=31&t=15399&start=280 Re: Latest floor plans for Mt Barker build - ranch style (Mk 2) 8Apr 22, 2009 11:18 pm Yeah, opening up the rumpus room is the key. The best thing about this house is you can have 3 pool tables. It really doesn't get much better than this! Re: Latest floor plans for Mt Barker build - ranch style (Mk 2) 9Apr 23, 2009 6:30 am bigred Yeah, opening up the rumpus room is the key. The best thing about this house is you can have 3 pool tables. It really doesn't get much better than this! Only 1 pool table (and arcade machine). The Home theater will have a front projector but also double as a formal lunge. Cheer one and all. Open for more comments though. Re: Latest floor plans for Mt Barker build - ranch style (Mk 2) 10Apr 23, 2009 7:11 am Looking good Metter... Couple of things... The small nib wall left from removing the rumpus room door in the hallway, the nib on the kitchen side... I'd remove that... Maybe push the master door back into the room a little, in line with the bed 2 wall, otherwise you'll have this little nook that is wasted space. A longer hallway there will open the house a little... What about a sliding door off the family room to out the back also? Only thing is, make it the same size as the meals door... With the master bed doors, it may look a little funny to have french doors when the rest of the house is sliders at the back... I'm not sure what the purpose of having the french doors in the rumpus is... Maybe look at making the two windows in that room 1800mm high, rather than a door... Not sure which way the home theatre is going to be layed out, but i'd swap the location of the rumpus and theatre storage areas... That way the doors aren't so obvious in the rumpus room when you enter the house... Also beaware of the kitchen breakfast bar if you plan on having a cantilever bench.... Little kids running around that corner will knock their head everytime! I'd suggest a full panel on each end to prevent that! Possibly make the kitchen window larger... I'd almost make all the windows/doors in the kitchen/meals/family area the same size... 2100mm... The bedroom windows look like they are 1500 wide... I'd go for bigger on those... 1800mm minimum, possibly even 2100... With the rumpus room window/door combination, I'd centre it about the room internals, like the home theatre is... With bathrooms, have a think about where you will hang the towels... Sorry if I'm throwing so many little things at you... I've been in the process of drafting my own plans for the last 2 years, and keep making slight improvments along the way. I think you've got a good workable layout that can service a family well! Keep us updated on the progress... When are you planning on building? Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! The Dulux colour consultants are awesome. If you show them the photos they should be able to figure it out for you straight away 1 1681 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16813 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17691 |
