Browse Forums Home Theatre & Automation Re: Postpone our home theatre plan 2Apr 16, 2009 10:24 pm Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Postpone our home theatre plan 4Apr 17, 2009 1:51 pm Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Postpone our home theatre plan 5Apr 17, 2009 2:02 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Postpone our home theatre plan 8Apr 17, 2009 9:45 pm It is easier as when you get to the outside walls (external) you can lift the tiles to make it easy to get cables down the wall. You cant lift a sheet of colorbond If all the cables are in internal walls then this is a little less of an issue. It is still possible but a lot more work and a bit more expensive as there is more time / energy /effort involved. Re: Postpone our home theatre plan 9Apr 17, 2009 9:59 pm mattwalker It is easier as when you get to the outside walls (external) you can lift the tiles to make it easy to get cables down the wall. ahhh yes that makes sense now... come to think about it,this is what the foxtel guy did when he installed the satellite at my rental here.... I'll be glad to get rid of satellite though and go back to cable in the new house... sick of not getting all the fta channels in the one box! i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17287 5 10494 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25172 |
