Browse Forums Home Theatre & Automation Re: Home Automation 3Apr 10, 2009 7:28 pm Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Home Automation 6Apr 13, 2009 9:08 am Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Home Automation 10Apr 13, 2009 10:14 am Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Home Automation 13Apr 16, 2009 4:46 pm With Wireless the entire bandwith is shared. Streaming wireless G between two wireless networks means a speed of 27Mbps (as its 54/2 at PERFECT reception, which NEVER happens). Make it 4 devices and half it again... For our new place Im networking to the kitchen bench where a phone socket will be, and to two points where TVs are likely (lounge and HT room). They will use that to run my HTPC setup and avoid all wireless problems. outside Ill have a wireless music player at some point Id say, and that will be wireless (or run a cable from the kitchen when needed) as music streams much easier. Re: Home Automation 14Apr 16, 2009 4:55 pm I'd agree with cabled also to your major areas. hellman, are you running any to the bedrooms? Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Home Automation 15Apr 16, 2009 5:05 pm wired ftw..... full home autmation is over kill unless you have the money and the need for it... Cat6 for cabling, RG6 quad shireld for TV outlets, central spot for all wiring to end up. Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Home Automation 16Apr 17, 2009 10:35 am ozzroo hellman, are you running any to the bedrooms? No there is no plans too ATM. Maybe in a few years, but I cant see the need for them ATM. The cabling is all going back to one bedroom so it will be the study, but otherwise no. Re: Home Automation 17Apr 17, 2009 12:04 pm I was looking into the X10 about 6 mths ago. Looks okay as a hobby home automation kit and you can build on it. Much of the system you could integrate yourself. But like many things I think it would be fun for the first few months then the noveltly wears off and it will be another money waster. If you are really into wanting it go buy the X10 CM15 Pro kit for about $200 with the PC controller and one bayonet/one device fitting. Then you can load the software and play around turning on a lamp or toaster via macros in the software. For some of these tasks, the delay on the powerline is not really noticed if you are using it for security "all lights on" before you get home etc. Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: Home Automation 18Apr 17, 2009 1:13 pm Hellman109 ozzroo hellman, are you running any to the bedrooms? No there is no plans too ATM. Maybe in a few years, but I cant see the need for them ATM. The cabling is all going back to one bedroom so it will be the study, but otherwise no. at least get the holes pre drilled at frame stage, and a pull wires/ string installed and or ridged conduit installed... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29178 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 17493 10 12689 |
