Browse Forums Building A New House Re: Pls Help. Builder cant provide brickwork above sliding door. 3Apr 14, 2009 8:31 am John, Tarin and the Kids Built and moving in to the Regent Grande with Masterton homes http://thebrownsaremovingtothecountry.blogspot.com Re: Pls Help. Builder cant provide brickwork above sliding door. 10Apr 15, 2009 9:58 pm It can be done but it need a non standard L lintel. Metricon actually use an L beam in many of there garage door openings. Basically what they need is a 5.2m 10mm L bar 150mm X 100mm with an additional 100mm welded on the back to form a 250 X 100mm L bar. Now using those measurements you will need around 3 preferably 4 courses of brick work. The bar will cost aroun 400 to 500on its own. plus at least 100-150 dollars in brick work. Re: Pls Help. Builder cant provide brickwork above sliding door. 12Apr 16, 2009 6:10 pm borg It can be done but it need a non standard L lintel. ***** actually use an L beam in many of there garage door openings. Basically what they need is a 5.2m 10mm L bar 150mm X 100mm with an additional 100mm welded on the back to form a 250 X 100mm L bar. Now using those measurements you will need around 3 preferably 4 courses of brick work. The bar will cost aroun 400 to 500on its own. plus at least 100-150 dollars in brick work. That's what I like to see, a specific and spot-on answer to a question. Well done borg. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Pls Help. Builder cant provide brickwork above sliding d 13Jul 02, 2021 8:46 pm Needs TBAR which needs crane which is $400 or more, if the crane can reach Re: Pls Help. Builder cant provide brickwork above sliding d 14Jul 03, 2021 12:37 am I'd say some time in the last 12 years they found an answer. That is some deeeeeep digging! Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 The frame work needs to be fully and adequately supported as they are most of the time the load bearer. A steel angle bolted to slab edge and bottom plate could do the… 1 289 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 17250 |
