Browse Forums DIY, Home Maintenance & Repair Re: Hang 10kg mirror on dry wall. 2Apr 18, 2024 11:39 am firstly, this is sold to you as a floor mirror. Considder that for a moment. If you want to still hang it, there are lots of options for hanging stuff on drywall. But the simplest and best options i have seen for heavy objects is the 3M Claw. You could use some framing/hanging wire from one side to the other and hang the mirror via wire on a single central claw. You can get it from bunnings and there are lots of videos for it online. SImple, effective and minimal damage to the wall. Re: Hang 10kg mirror on dry wall. 3Apr 18, 2024 12:06 pm In Australia we call it plasterboard or gyprock - not 'drywall'. Which ceiling hook to use to hang Xmas lights under Eaves in 1st floor in 2 storey façade (no… 0 1446 It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils. 10 9677 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 6755 |
